Question about Cell Phones
Ring length my nokia 6120c-1 mobile phone doesnt ring long enough before going to voice mail. How can I change this?
  • 86 Answers
HI go to ur mobile's setting > restore fectory setting > 12345 code > restart ur phone. call costmour care and deactivate ur voice call. i hope my idea is very greatfull to u. keep voteing.
Posted on Mar 15, 2008
6ya staff
SOURCE:
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
How to extend the rintone length on my binatone 2210 it is far too short. when it rings I can't get to in time it only rings about 3 times, and the person thinks i am not there.
When it stops ringing, the caller goes to your voice mail, right?
If so, then you need to contact your phone company and have them change your "Ring Cycle" -- that's the number of rings before the voice mail system picks up.
Some phone companies have a way for you to do this yourself from their website, other require that you call up the customer service line. Either way, the thing you want to adjust is your voice mail ring cycle.
Sep 27, 2010 | Lands Phones
Ring tone cuts out too fast. How do I prolong dialing tone so thst I can grt to phone before it cuts out?
When the ring tone cuts out, your caller goes to your voice mail, right?
The length of time before an unanswered caller goes to voice mail is called your "ring cycle" and is set by your phone carrier (e.g. Vodaphone, Verizon, Orange, etc.)
There shouldn't be any charge to change your ring cycle, and some cell carriers will let you adjust it from your account settings on their website, but the simplest answer is just to call your carrier's customer service and ask them to change the ring cycle for your number.
For cell carriers in the US, you can call 611 from your phone to reach your carrier's customer service, but I don't know about other countries' mobile carriers.
Feb 11, 2010 | Cell Phones
Nor ringing long enough before going to voice mail
Try going into your settings/call settings/call divert.
Go into Call Divert and cancel all diverts.
This should solve your problem.
Aug 26, 2009 | Nokia N73 Cellular Phone
Incoming calls go to voicemail after 2 rings,
ur phone is setting voice mail obsence so reset ur phone disconnect the voicemail
Jul 09, 2009 | Nokia 6500 Slide Cellular Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
Ringtone
This is a network specific setting. Type into phone (what iws written in the right box).
Set number of rings **61*YourVoiceMailNumber**N#@
YourVoiceMailNumber = your voice mail numer
N = Ring Time (up to 30sec)
@ = Send/OK button on your mobile phone
Dec 14, 2007 | Nokia 6120
Phone Doesn't Ring Long Enough Before Going To VM
The phone you have can be used on different Avaya phone systems that program differently. It is certainly something that can be changed but you would need to know which system you have first. There is a call-forward no answer timer that send the call to another station or voice mail box etc.. after so many seconds. That is what needs to be changed.
All the manuals are available at www.avaya.com but again, you would need to know which system you have before looking for the manual.
Nov 15, 2007 | Lucent PARTNER18 Corded Phone
Cell Phones Logo
256 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
