39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
If the DVD works through this "box". Things are looking alright. There must be a number of inpus or hookups to connect VCRs or DVDs or what ever to this "box" that then allow you to hook tp the TV.
If this is the case there has to be a way to swithc the box to the different things hooked to this box so that you can see& hear them.
I do not know what this box is, but can only guess you need to get the manual or more info on how it works.
If you can try to hook each one of your pieces seperately to the box.
First unhook the DVD that works, and hook the VCR. If works, unhook the VCR and hook up the the enxt piece. That way you'll know if each of them is working.
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go. If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV. Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Hi there-we tried hooking up a Gamecube system to ours and got the sound to work, but no video signal - the video is output only I think because we have been able to connect the DVD player to the TV and play DVDs and see them on our tv - hope the info is helpful.
