Question about Dishwashers
Dishwasher woes My LG (LD14AW2) dishwasher keeps cutting out and the E1 message appears. I have checked the hoses and there does not appear to be any leakage. Can anyone help. Thanks Lyn
  • NikkiCo Mar 12, 2009
    i have the same prob trying to find the manual for it to see what it says does anyone know where i can find one?
  1. ford fiesta -incalzire
Posted on Mar 15, 2008
SOURCE:
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher ld14aw2 error
Did the owner of the LG LD-14aw2 that was giving the OE error get the problem resolved?
With an OE (Drain Error), it means that the dishwasher is not fully drained out in spite of 5 min. drain operation. First step of the trace the entire path of the drain hose to the sink drain. Be certain that ther is no blockage in any of it.
It that does not resolve the problem, remove the lower spray arm and the screws that hold the sump area down. Open up the area and inspect everywhere for debris that could be blocking the drain area.
Next step would be to replace the drain motor.
With the LG dishwasher that is giving an IE error: Double check that the water valve supplying the dishwasher is fully open. Next, with the water turned off, open the connection between the inlet pipe (hot water) and the dishwasher inlet valve. Clean the screen of all debris/minerals that often build up there.
If problems continue, check and replace the inlet valve.
Thanks for reporting back what you have found. Good Luck!
Dec 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
167 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
