Bosch HBL8750UC Electric Double Oven Logo
Anonymous Posted on Mar 31, 2010
My bosch HBL8650UC shows an error code e218 then it shuts off
BOSH oven doesn’t work properly because of function error E218
The E218 error indicates a problem with the lower cooling fan. The fan could be moving too slowly or too fast. There may be something blocking the fan or a damaged wire providing the wrong feedback to the control board.
You can try resetting the error by disconnecting the power for 5 minutes or so. Turning off the power with the appropriate circuit breaker is the easiest option. Then check what happens when you start the oven again. If the problem recurs, then you need to check the wiring and for anything interfering with the fan circulation. The Hall Effect sensor should also be checked. Most often the fan needs to be replaced.
Please add a comment with the model number of the appliance for specifics for your oven.
I hope this helps.
Jul 04, 2018 • Ovens
Bosch hbn565 oven error code E218
E118/E218 Four possible causes.
Reversed high and low speed wires
Hall effect sensor not seated properly
Wire routing coming in contact with the rubber end cap on the cooling fan
Upper plenum coming in contact with the rubber end cap on the cooling fan
Apr 27, 2018 • Bosch Ovens
Haw to stop ae118error for bosch oven HBL5450UC/02
Mar 18, 2018 • Bosch Ovens
1helpful
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 • Bosch Ovens
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 • Bosch Ovens
Model ME302ES/02 getting an E218 error code- what does it mean?
that code is detecting a failure with the cooling fan
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/angel_c86b9a09ba26c783
2answers
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 • Bosch Ovens
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
