Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
How to take apart HP C4180 All-in-one
I can only remove the side panel and i dont know how to take apart the rest to fix my phantom paper jam~! please help~!
After talking to HP tech support and tring all the textbook fixes for my false paper jam,I think i have found the problem,at least mine works like new again!!!!! Take the left and right side covers off,,,,make sure your unplugged! On the right side off your ink tray is a small box with a lens on the bottom make sure that is clean..... On the left side you see a few large gears,,,on one near the center is a clear disc with numbers on it,,,,,,turn the gear closest to the corner back and forth,,,,clear plastic disc should turn also,,,,if it does not,,,gently turn it with your finger tip,, it should tighten up... Line it up so black sqare is at the bottom,,,,,slide ink tray to center position,,, restart printer,,,good luck
Posted on Mar 23, 2008
  • johnoshaugh
    johnoshaugh Mar 15, 2013
    excuse, but how do you take the LEFT side off there are no screws and the trays for photopaper are there
    Sergeant:
    Champion:
  • 210 Answers
i understand that you are facing a paper jam issue.
Am I correct?
ok.... open the rear access door on the printer. the door at the back side of the printer. before opening it, make sure that you unplug the power chord. you will get full access to the rollers. you have to gently pull out the jammed paper from the printer.
once that is done, you can clean the rollers using a lint free cloth. after that you can close the rear access door and try to copy.
thanks and regards
agnel
Posted on Mar 15, 2008
How do I fix the "phantom" paper jam on HP P3015?
Just had one today that would throw a open rear door error. Turned out that the flag in the back of the fuser was dislodged.
Sep 29, 2014 | HP Office Equipment & Supplies
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
C4180 paper jam problem
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Office Equipment & Supplies
Phantom paper jam
Same as sarahfrank and have tried all the suggestions on the hp web site.
Nov 03, 2008 | HP PhotoSmart C4180 All-in-One Color...
Hp deskjet 9800 power and paper out lights flash together
Remove the back jam access cover and see if there is anything in the way. Also, Try removing ink gunk from the resting area.
Jun 16, 2017 | HP DeskJet 9800 InkJet Printer
HP C4180 Carriage Jam
Lisa,
you can call HP technical service which is open 24 * 7 and the phone number is 1 800 474 6836 for US customers.
Customers of other countries can open the following link: http://welcome.hp.com/country/us/en/wwcontact_us.html
There is a high chance of the printer hardware failure. If the printer is under warranty, HP will replace the printer for you.
May 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
hi,
i think you are getting a false paper jam.
> try this.
> unplug the power chord from the printer
> check whether there is any paper or any bit of paper stuck inside
> if so remove it
> if not, clean the rollers
> now plug the power chord
> check whether you are getting the message
> if you are getting try below
> open the front door so that you will get full access to the cartridges
> now move the cartridges manually from right to left several times
> check again
> if still you are having the problem
> service the unit
Mar 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
Paper jam
Does the papoer jam light come on right when you turn it on or just after you try to make a print?
Oct 25, 2007 | HP PhotoSmart C4180 All-in-One Color...
Hp photosmart c4180 - phantom paper jam
Had the same paper jam problem. Opened the LHS panel what Mitryp had suggested but just with a light push of the clear wheel back to its place and it worked perfectly. No glue was applied. Make sure you don't mess with the sensa.
(See best solution above for detail on how to open the LHS panel)
Sep 19, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
2,215 people viewed this question
Seeker5211
Seeker5211
