Back to:
Tags:
Acer AT2001 20 in. EDTV-Ready LCD Television
Acer AT2001 cannot use as monitor (by 2 users)
posted by weipawalters on Mar 15, 2008
Hi
When I plug my Acer AT2001 into my PC the screen divides so that the left hand side shows on the right of my monitor and the right shows on the left of my monitor. The mouse still acts like the screen is normal so it is very difficult to use. There was no driver with the TV do I need to download one?
Please help - very frustrating
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Synwicked, posted on Apr 06, 2008
at2001 says there is no signal and goes into sleep mode
trying to connect acer L410 tower (vista)
i have no other moniter to try to startup with
PS. moniter works in safe mode but i am unfamilar with vista and see no option for display properties, only system restore stuff
Solution #1
posted on Mar 15, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
You need to lower down the screen resolution of your PC prior to plugging in the Acer AT2001. The Acer AT2001 maximum/native resolution is 800 X 600. In some instances, lowering the screen refresh rate of the PC might also be required.
Pls don't be surprised if doing so, the icons would be a lot bigger and for some users might be inappropriate for desktop use. Additionally, it will be very bright.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Acer AT2001 cannot use as monitor:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
it does nothing when it is turned on the fuse is noblown...
I have a NEC HT 1100 projector. It was working fine now I...
who can help me to solve my problem..i really need the...
my husband bought a tv and he threw away my manual. And...
Acer AT2001 20 in. EDTV-Ready LCD...
I dont seem to be able to get good color,, cant seem to...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
