Question about RCA DRC8320 DVD Recorder/VCR
No power anymore
It started by occasionally locking up on a menu page, but then this increased. Now neither side (VHS or DVD) works at all...
We did upgrade our directv service recently (new receiver) but we never had any incompatibilities before.) Any help/advice would be welcome.
It's not a problem with your Direct TV upgrade. We had the same problem, and evenutally the unit refused to even power on. We had received an interface error message, which instructed us to power off the unit. It never came back on.
Ditch the unit and get a new one. You will be glad you did.
Posted on Mar 22, 2008
SOURCE:
Magnavox vhs and dvd player vhs insertion issues
Someone is going to have to take the unit apart---mechanism issue with the tray or the gears that lower it etc---not too many shops left that work on VHS decks anymore so call around first.
Dec 03, 2012 | Televison & Video
A BTPASS CODE FOR COPY PROTECTION FOR A LG RH2T160 DVD RECORDER
Try this one:
Press Home on remote.
Go to setup
Scroll down list to highlight lock icon
Press 0 seven times
You will get a message saying "Congratulations Region Change Free [Yes]"
Press enter on remote.
Hope that helps........
Aug 26, 2008 | Televison & Video
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
Acer Aspire 4310 -- DVD ROM not working! It was started when i inserted a dvd on dvd drive and it stucked up. It was about 3 days when the dvd was removed by using a needle. Then all it started not to...
HI,
Welcome to FixYa. I believe that you are having problem with your DVD ROM, here's how you can fix your problem.
1. Click on START
2. Type REGEDIT on the search bar on START Menu or the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
Hope this will help.Thank you for using FixYa.
Mar 20, 2011 | Acer Computers & Internet
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Menu question
if the tapes are store bought movies (on vhs) you will need to buy a copy guard eliminater...you dvd recorder was made not to record copy protected materal
Dec 07, 2008 | Samsung DVD-VR357
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Jun 03, 2008 | Panasonic DMR-E75V DVD Player/VCR
DVD/VHS Selection
turn of the power on wall, and wait 5 mins, then try again. i had same trouble with not being able to eject or play dvd, i turned off player at wall and it worked fine again.
Sep 25, 2007 | LG V181 DVD Player/VCR
RCA DRC8320 DVD Recorder/VCR Logo
77 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
