Sim insert where
Removing a sim card from amotorola cell phone, what location on the back of the phone
  • 46 Answers
Whats the model of the motorola phone?
Posted on Mar 15, 2008
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
Mar 29, 2014 | Samsung Galaxy Cell Phones
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
How can i put sim card on my cellphone
the back of your phone and under the battry and bam there it is put your sim card right in the sim card hole
Apr 14, 2012 | LG enV3 VX9200 Cell Phone
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
My blackberry curve screen shows a SOS in the upper right.....I cannot make an outside call.......it blocks with a message "emergency calls only"! A message at top of screen says"insert SIM card". What...
The message you are getting from your phone indicates that no sim is present in your phone,perhaps you have inserted the sim in a wrong manner, hence the phone does not recognize the presence of the sim card.
Here is the solution;
1.Remove the back cover of the phone and remove the battery respectively,
2.Afterwards,re-insert the sim card in a manner indicated by an arrow located beside the sim port,or as described by the user manual.
3.Ensure you turn on the radio connection,which is located in the manage connection settings in the main menu.
Problem solved
Have a nice day...
Aug 04, 2010 | Cell Phones
I can't find the part in my phone for the sim card!
The SIM card on a Nokia 6085 cell phone is under the battery.
Remove the battery
There is a metal sim card holder located near the base of the phone.
Unlatch it with your fingernail and swing it up.
Insert the SIM with the notched corner first.
Apr 24, 2010 | Nokia 6085 Cellular Phone
Motokrzr sim card
Yes, you can use the same SIM card on a Blackberry and Motokrzr
To access the SIM Card on Motokrzr, slide open the back cover and remove the battery. The SIM card is located towards the top side of the phone
Dec 10, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Insert sim card
If you want to insert your sim card into your mobile, open the back cover, remover the battery and insert the sim into the slot provided. Put back the battery, close the back cover and then use the mobile.
Nov 01, 2008 | Nokia 6300 Cellular Phone
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
