Hi I have a about 2000 model precision power amplifier 2600 it has lost one channel it is a two channel car amplifier it is signed by a recently deceased racing car driver I have had an electronics bloke have a look at it and he seems to think a hybrid module numberd 09-2515-1000 369643 15 pins to be at fault could you lead me to some where I might be able to purchase on of these items thanks Steve
You have to rebuild the board.
Posted on Mar 03, 2009
6ya staff
SOURCE:
How do I find an an electrical schematic for a Gromes Precision GTE 100 amplifier?
http://www.grommesprecision.com/precisionelectronics/literature/literature.htm
Jul 31, 2014 | Grommes-Precision AX250 1.5 Input Channel...
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
Channel b not working
Likely the amplifier has an electronic failure that will require servicing.
May 19, 2010 | Peavey Pv 2600 Power Amplifier
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
6000d amplifier cutting off
Hi...
Crown has posted on their website all the tech info you can probably use for your situation.
Cheers!
Jan 15, 2009 | Crown XTi 2000 2-Channel Amplifier
Pb2600 car amp
It might, at say...6000% distortion. For a true amp power rating look for the RMS per channel specs. This is a much more realistic rating of what the amp can actually put out continuously...
Mar 21, 2008 | Lightning Audio FF150.2 Car Audio...
Need owners manual
Here is an archive of PPI PowerClass amp manuals...
http://narbi.free.fr/manuels/Amplis/Precision%20Power/Serie%20Powerclass/
Jan 30, 2008 | PPI PC2600 Car Audio Amplifier
87 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
