Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Suddenly stopped My western digital my book 250 external hard drive just stopped working. I thought it was the power pack so I got a new one. I've plugged it in and pushed the on button and it still does not come on. Help, I need to retrieve my data. off and out wi
    Brigadier General:
  • 6,966 Answers
If the unit will not power on even with a new known good power pack, then it can be assumed that there is an electronic fault internally.
This of course would require that the unit be opened and voltage readings be taken. If you are comfortable working with electronic circuitry and components and use of a DVM, then it is possible to do the repairs yourself. Otherwise it would perhaps require you to seek the services of a qualified professional.
Additionally, if you are after retrieving the data inside the actual hard drive itself, there are two (2) possible ways of doing that by removing the actual hard disk from the My Book enclosure and:
1. connecting it to another enclosure or IDES/SATA to USB interface; or
2. connecting that HD internally in a desktop PC as either a Secondary Master or Slave.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 15, 2008
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
The light on the hard drive is on but my laptop isnt recognizing that it is connected? I have no problems for the last 12 months then suddenly it stopped working
Have you try to use other cable or test it to other computer?. If the problem still the same then their is a chance that your external drive are already deffective. Try to visit a store catering hard disk recovery for any possible chances of recovery. Just a thought hope it helps thanks.
Sep 23, 2011 | Western Digital My Book Essential 1TB...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Western Digital 250 GB MyBook external HDD not responding
If you've tried removing the disk-drive from the casing, and attaching it as a "slave" drive in some desktop computer, and you still have the problem, then you have a _BIG_ problem. Search online for a professional (and not inexpensive!) "Data Recovery Service". They should be able to disassemble and repair your disk-drive, just long-enough to extract all your precious files, and copy the files to DVD-recordable media or to a brand-new disk-drive.
Jan 07, 2010 | Western Digital My Book Essential Edition...
MY WESTERN DIGITAL MY BOOK 500 GB WILL NOT COMMUNICATE WITH MY COMPUTER. I'VE CHECKED THE USB CONNECTION AND THEY WERE FINE. WHAT DO I DO?
Power down the drive, disconnect it, and then power it back up ... does it come up? If not, get new drive. Connect the drive to a known-good USB port (e.g. one that you've demonstrated your mouse can work on). Does Windows recognize it (****, "Installing External Device", etc.)? If not, try downloading new drivers from the Western Digital site. If it is recognized by not responding, you have a hard disk failure. If it is new, return it to the manufacturer ("infant mortality"). If not, good thing you have a back up, right? If you need to get data off of it, you may find you can get short-term access by using some low level disk access tools, available on Sourceforge.net.
Oct 14, 2009 | Western Digital My Book Essential Edition...
Western digital passport i/o device error
90% of the time this is a power problem. The USB port on the computer can not supply enough watts. Use an external USB hub that has a 5V power supply.
Oct 14, 2009 | Western Digital 250GB MyBook External USB...
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
59 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
