Question about Gateway 450ROG Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
Gateway 450ROG - will not start. When powered on the fan starts and the DVD/CD ROM Drive light beside the power button turns red.
    New Friend:
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Posted on Apr 29, 2010
SOURCE:
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
This device cannot start. (code 10)
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
click start control panel administration tools computer management device manager scroll to cd/dvd rom
you might see a yellow question/exclamation ? ! or a red X right click to update driver
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 22, 2012 | Gateway Computers & Internet
CD/DVDW ROM drive won't start
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 25, 2012 | Gateway Computers & Internet
I have a Gateway Solo model 400 The cd drive does not operate. When I power up the led on the drive lights up several times. When I try to do anything with it, however, either reading data or audio,...
you might have to uninstall your cd drive restart your computer then reinstall the cd drive also
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 23, 2011 | Gateway Solo 400VTX, 450RGH, 450ROG,...
My cd/dvd drive isn't showing up in "my Computers" and further more when I insert a cd or Dvd nothing happens. i tried downloading a dvd driver from dell but the problem still continues. What shall i do?
what is that? laptop or desktop, because laptop isn't easy to open and but in desktop you can change dvd drive.well, if you drive is not showing anything, that means either is disable or is not connected properly? have you seen that your drive's property?just right click away to check and any lighting indicated process, the LED light will start blinking if the computer is communicating with your drive. good luck,
Jun 21, 2010 | Sony DVD-ROM DVD Drive
When turn on comptuer the screen show red, blue, green squares scrolling, cannot see boot process. What is causing this?
Most probably you either have a loose connection between your monitor & your PC, or the data cable connecting the monitor & the PC is defective & needs to be either repaired or replaced.
You can try to use another cable of the same type & see if this will fix the problem.
Jun 08, 2010 | Gateway 450ROG 15inch SXGA+ LCD Display-...
Gateway laptop
The first link shows what the status lights are, and the second is for the user guide. I believe the status light you're seeing indicates that the module is ready to swap. This refers to the modular bay or your CD drive. This is covered on page 52 of the user guide. It appears that you have hit the safely remove hardware icon, and most likely turned off the CD drive. Release and slide the drive out and put it back in. This should reset it, and the light should go off or turn green.
http://assets.gateway.com/s/Mobile/Gateway/450ROG/3501353ivr6.shtml
http://assets.gateway.com/s/Manuals/Mobile/9528975.pdf
Jul 26, 2008 | Gateway 450ROG Notebook
No POST, DVD-ROM symbol lights red
well ya if pin getting llose nee dto buy new jack on ebay remove whole mobo solder in new jack or u could try new power supply ok maby old one not getting right amout of power to it ok happends alot cheak cable on lcd pushed down in socket dint get loose did it
Jan 07, 2008 | Gateway 450ROG Notebook
How can i make my CD ROM display
Open the case and check for IDE CABLE if it is correctlly connecter to the mother board.CHeck for the JUMPER if it is SLAVE OR MASTER! if still not working change IDE cable!
Oct 18, 2007 | Gateway 450ROG 15inch SXGA+ LCD Display-...
Gateway 450ROG Notebook Logo
314 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
