Question about Cyberhome CH-DVD 300 DVD Player
Need help on DVD power supply repairing..
My DvD player wont turn off, ive just replaced the Fuse, samething happen.. no power.
ive read all your comments about no power on DVD player... and you said that replace the capacitor of power supply... but im confuse... which one? i have a tester but how can i test the fried capacitor?
Thnx!
  • Endless Mar 15, 2008
    my c10 is 1000uf 10v and my c11 is 470uf 16v. are these two needs to be replace?
    ive done soldering before.. its no problem with me.
    well, i hope it would work.. im doing it now.
  • Endless Mar 16, 2008
    sad to say.. ive just replace the c10 and c11... but its the same..no power at all... any more ideas?
    Problem Solver:
  • 9 Answers
You dont ,,just replace c10,and c11,,,youll need a solder iron,if you havent done soldering before find someone that has done it before,,youll see c10,c11 stamped on circuit board.
See how much voltage your getting on outputs 12 on one side 5 on other
report progress
Posted on Mar 15, 2008
My dvd wont turn on
is there any power indicator? if none,look for the power supply board replaced blown fuse. if the fuse is blown with darkened color that was mean their is a shorted component parts in the PSU or in the main board.usually rectifier diode and regulator ic.hope this can help just let me know if you need further solution.
Jun 25, 2012 | Televison & Video
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
Power light blinking on sony dvd player
Repair of a portable unit with a power supply problem inside it is likely not to be economical and parts for these units are rarely available.
No magic wand for this issue--unless was a very expensive unit replace it--
May 02, 2012 | Sony DVP-FX930 Portable DVD Player
JD-VD502 DVD player blew a fuse. I replaced it with a 1-amp 250 volt from radio shack but as soon as I powered on, the fuse flashed and blew again. I tried twice, same result. Is there a reason this keeps...
Hello
Never put any fuse in it and switch ON. It has some short with internal circuit, and should be repaired before installing a new fuse. The fuse use is as a protection device to protect the other circuit parts from further damage. If you will put an other fuse, and switch it ON again, you are making things more worse than present. Find out the reason for buring out fuse. If you can do it by yourself. Otherwise get it repaired by any experienced service personal. Never make it irreparable. OK.
May 07, 2011 | Jwin JD-VD502 DVD Player
I turned the DVD player off last night and this morning it will not turn on. Any thoughts, suggestions? I do have a DVD in the player that I need to get out somehow....
it is possible that the power supply unit in the DVD has failed. You will need to open and ccheck, the fuse might be open and if a new fuse blows out then the SMPS unit is faulty.
Possible that the Sm driver IC /driver has failed. Possible also for allied components to have failed.
Or else you can change with a new unit.
Helpful?
Aug 28, 2010 | Samsung DVD-V3500 DVD Player/VCR
Dvd player wont turn on..
No brand/no model number= only general reply.
If the fuse blew, it is indicative of a failed power supply.
Always include needed information since no one can help yo unless you help us.
Dec 29, 2009 | Televison & Video
When I plug the unit in and try to turn it on, nothing happens. toshiba sd-3980 dvd player
The internal fuse is blown.
It may be a replaceble glass cartridge fuse, or a fuse soldered to the power board.
Unplug, remove top cover, check and replace fuse. Radio Shack has reasonable coverage of fuses.
But - fuses usually blow for a reason. It could have been a power surge; it could be an internal failure. If the new fuse blows, it needs professional replair. Many of these are so cheap to make that it doesn't pay to repair them - replace it if the repair estimate is over 1/2 the replacement cost.
Nov 01, 2009 | Toshiba SD-3980 DVD Player
Unit won't power up. Have checked fuse, Good. Now what?
Check out this website for troubleshooting tips and repair of you dvd player. Paste the website into you address bar. http://www.drx9000repair.netfirms.com/ They have a lot of information on repairing these players and they also do repairs.Hope this helps you with your problem.
Apr 12, 2009 | Cyberhome CH-DVD 300 DVD Player
TreTech TT320 dvd player will NOT turn on
The fuse is usually blown when this happens. If you know how to find the fuse and replace it this should give you power on again. If this doesn't help then you may have had power surge and just blew the mother board. If this is the case then you may just need to get a new one for they are really priced low now.
Jan 08, 2009 | TruTech TT320
Doesn't do anything now
The CyberHome CH 300 is a good, inexpensive DVD player with a power supply board prone to fail, because of a few weak components, especially if left turned on and not used.
Usually, if the power supply fails, the red light will not illuminate when plugged in, and of course not turn green when turned on.
If you have this specific problem, I can repair the power supply for $20.00. Contact me at FrancisH49@hotmail.com to arrange shipping and return of the repaired board.
Sep 21, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
101 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
