Question about Car Audio & Video
92 240sx dash wiring to sr20 ecu harness diagram
I'm having a major harness problem!! last two mags i bought had sr20 into 240sx conversions but left out the wiring from the stock dash harness to the new sr20 ecu harness. my car now has no spark and no fuel pump activation. its like the ecu isn't reading the car is in run/start position. what the hell can i do i can't find any diagrams showing this issue? i thank you for any help you could send my way.
I knw how but i dont have wiring diagram.can u send me a copy so that i can explain to u
Posted on Nov 20, 2008
Pcm wiring diagram
There isn't much to the wiring diagram There is only two wires to the N75 turbo control solenoid.Pin 2 on solenoid green and brown comes from the ECU pin 64 and Pin 1 Green and white wire goes to a 10 pin connector in the plastic channel on the left side of the engine bay pin 6 and then that then goes on to connection 2 (87) in dash panel wiring harness.
Jul 11, 2014 | 2000 Volkswagen Golf
Would the wiring harness from a 1997 match up with a 1995
no it wont, the ecu pinout is different so the harness while major functions will work, it will not be fully operable. If you have no other choice then use it, but you will not have proper performance from your ecu.
Apr 26, 2011 | 1995 Nissan Altima
My anti-lock brakes light on the dash is on....what could be causing this?
Problems with ABS can be frustrating. You have senors on the front wheels, you have wires that run to the sensors, plus you have the ECU mounted to the master cylinder or on the fire wall depends on other options. Now the wheel sensors work like little alternators. Your wheels will have a gear that the senor reads as the wheel turns and then creates an A/C voltage that tells the ECU unit that the wheels are turning. Having a ABS code could mean that wiring to one of the sensors is broken or has fallen off, or is corroded at the plug end. Your ABS system has four major parts the ECU, an ABS hydraulic unit and the wiring harness to the wheel sensors, then last the sensors themselves. You will need to check all the wiring harnesses to each If you have a multi meter you can read the voltage of each wheel sensor at the other end of its wiring harness. Jack up the front end and find the end of each wheel sensor harness and spin the wheels by hand. you should get a reading on the AC voltage scale of about ..45 volts. not quite a half volt. when the wheel stops the meter should go to zero. spin the wheel and the meter should show voltage. That will tell you if the sensor and the wiring is good. The ECU has no trouble shooting it is good or bad.can't help you there. same with the Hydraulic unit. Most times it will be a wire broken or a bad wheel sensor. Good hunting.
Oct 20, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
I need the fuel system diagram for a 1998 Chevy Tahoe w/ 5.7L gasoline engine
Dark green provides power to fuel pump relay from the ECU. Orange wire at fuel pump relay is power at all time and is provide from the ECM/Bat Fuse at fuse block (Left side of dash). It also connects to the fuel pump oil pressure switch. The grey wire at relay provides power to the fuel pump and fuel pum oil pressure switch. The red plug thats tape to harness from relay/fuse center is the prime connector..
Jun 11, 2010 | 1998 Chevrolet Tahoe
Wire diagram
if you call the local stereo shop they likely have a conversion wiring harness or can build a proper 1 for you so you can allways remove it and reinstall original if nessarry
Jan 28, 2010 | 2007 Suzuki XL-7
93 toyota camry 2.2l replaced the distributor unit complete and still won't start, it has no spark.
you have 1 of 2 things
1 a broken can shaft ( not likely )
2 broken timing belt ( most likely )
Jun 29, 2009 | 1993 Toyota Camry V6
1989 to 1990 Powered door conversion
about the only advice i can give is that i did the same thing with a 94 probe base and a 94 gt. i had to take the whole wiring harness out of the gt and put it in the base. It starts from the inside fuse block, goes to both doors, under the front seats, all the way to the fuel pump, abs, tail lights, and pretty much everything from the dash to the rear of the car. If you can get a whole harness, it should work.
Mar 09, 2009 | 1990 Ford Probe
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
I need a 2005 Chrysler 300 wiring diagram
You don't need to touch your harness for the fog lights as its a major harness and is connected to many other things. You need to pop out the light switch opn the dash. it pops out and in the back of it you disconnect it. It has a conector on it. Buy a new switch at dealer, aprox $90 canadian and snap it back on. I know my fog light switch went last year. I have same the same car.
Dec 10, 2008 | 2005 Chrysler 300
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
Car Audio & Video Logo
367 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
