Question about Dishwashers
EX600 Electrolux Diashwasher
My Diashwasher will not repond to touchpad buttons.
The only way we can get the machine to begin a wash cycle is to use the delay button, the start/stop button does not respond at all.
Yet the machine can start cycle by using the delay button only,,but we have to wait 1 hour every time we need to use the machine..Any on know what the problem is
  • Steve Donaldson Mar 15, 2008
    G,day Aborcass,
    The model Number is EX600 that is all that is stamped on the top of the door.
    I removed the touchpads and cleaned the carbon tips with Metho thinking its grime preventing the circuit board from sensing the touch press. But no go, problem still there. Checked the ribbon connector from top board to main circuit board inside door cavity, its ok.
    Problem must lie in main circuit board unless i missed something on the top board.
    i know that electrolux model number maybe be a different number in other countries..found that with Smeg Oven.on a previous post.
    Hope what i said helps to identify the problem.
    Cheers
    Donno97
    Its about 3 years old
Hi- I have had the same problem with my EX600. The problem was caused by water getting into the control panel (because the controls are at the top) We had to order the control panel from electrolux and it is now sorted. It is easy to install but costs about $110 AU.
Hope this helps!
Posted on Jan 26, 2010
    President:
  • 2,651 Answers
Wanna give the model number if possible, sounds like your're having a problem with the display board malfunctioning, theres a kit available for the fix need to know the model though, any chance this is under 1yr old??
Posted on Mar 15, 2008
  • Ron Coons
    Ron Coons Mar 16, 2008
    im here in the U.S.A, and our electrolux" Frigidaire" called here, has an issue with the circuits not responding to the start button but delay will work. the resolution has been to replace the display board.It actually comes as a kit with a new display and ribbon connector as well as a new circuit board housing. i wouldnt be able to look up your part here. but im sure if you looked up your display board. itll switch to a kit
How do I turn off the beeping noise on the Electrolux 7kg Time Manager washing machine the 5kg Electrolux Sensor Dryer? The beeping noises indicating a cycle has finished are very loud. Please help!
The acoustic signals operate when:
• The programme is completed.
• The appliance has a malfunction.
To deactivate/activate the acoustic signals, press "Drying level" and "Prewash" button at the same time for 6 seconds.
If you deactivate the acoustic signals, they continue operate when the appliance has a malfunction.
Dado
Mar 06, 2016 | Electrolux Washing Machines
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
Electrolux EX600 Dishwasher loosing power during wash cycle
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
Feb 26, 2013 | Electrolux Dishwashers
Electrolux front loader washer ewd1477 flashing start/pause button. interrupted during wash cycle by power outage. start/pause button now flashes and won't start any cycle.
Try to turn circuit breaker off, or unplug unit, for about 5-6 minutes. This is a hard reset and should reset the internal controls to restart the unit properly.
Dec 29, 2012 | Electrolux Washing Machines
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
ON button will not repond. There is no display. Fuse and socket are tested and OK. Machine stopped mi cycle.
appears to be an electronic control issue, as you have no display.it itself may have its own fuse, the brain of the machine stopped.
Jul 19, 2009 | Washing Machines
Dishwashers Logo
613 people viewed this question
Top Dishwashers Experts
