The cartridges may not be seated properly in the carrier or just needs cleaning. Remove the cartridges from the printer. Close the cover of the printer. Unplug the printer from the power source and leave it unplug for now. Here's a link to the Lexmark website to guide you on how to manually clean the nozzles of the cartridges. http://bit.ly/9ZpYd1 . On the page, there are also other instructions on how to maintain the cartridges using the Lexmark software but that's applicable once you have resolved the alignment problem. Plug the printer back to the power source. Once printer's ready, re-insert the cartridges.
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
2. Then press the right arrow (+) twice; you should see the word Align.
3. Press Select. The alignment page will be printed out automatically
Next thing to do is reinstall the printers drivers and software. Click on the link below to get started:
