Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
DDE Share I cannot understand about DDE and how it use. In winxp sp2 by default this service is disabled why? is there is any harm to use this service
No folder option in my sys
Posted on Mar 15, 2008
View workgroup computers not available
Just run the Network connection wizard, simply run that. Ensure that the PC, you are working on, has, a Password, an Name, has Sharing enabled, on the DRIVES/FOLDERS you want. Then you should be OK.
May 21, 2010 | Microsoft Windows XP Professional SP2 for...
E-machine C2881 runs good with winxp sp1 hang winxp sp2
Press F8 repeatedly after turning on power and select safe mode. Then go to ctrl/panel - add/remove apps and remove sp2. Reboot.
May 16, 2010 | FIC Crusader VC37GV (73-40682-00)...
Excell 2007 very slow to open
Speed up Excel 2007 startup The Problem If Excel isn't running already, double-clicking a file will start Excel itself almost immediately, but the clicked file will be loaded only after about one minute.
The Solution At least on Windows XP the problem can be solved as described below.
  1. Application Explorer
  2. Menu Tools
  3. Menu item Folder Options
  4. Tab File Types
  5. List item XLS
  6. Button Advanced
  7. List item Open
  8. Button Edit...
In the dialog box that appears you need to make two adjustments:
Application to perform action:At the end of the line after /e append a space character followed by "%1" (including the quotes)DDE Application Not Running:Insert new text: [rem see command line] (including the brackets) Details We experienced the problem after updating to MS Office 2007. My father noticed that an Excel sheet gets loaded immediately if you include the path of EXCEL.EXE in the command line. Loading documents via DDE, as Explorer does it, seems to take much more time, at least if the application is not already running. The modifications described above will pass the file path immediately when the application is started, the DDE command that gets executed later on is only a remark, as an empty field would result in passing the default action from two lines above that field. The /e seems to ensure that Excel will not open an empty sheet, so I originally dropped that because usually no empty sheet is opened when a file is specified. However I got a report from someone using /e, and as it didn't cause any harm for me either, I now suggest to leave it in place. If Excel is running already, additional documents will be opened via DDE as before, resulting in only one Excel process running.
Word Time and again I've been asked whether I knew a similar trick for Word. Even without any tricks Word starts fairly fast, but even there adding "%1" gave me a slight increase in startup speed. I don't exactly know what this [REM _DDE_Direct] is. It looks like some kind of "special comment", that could have some effect despite being a comment. I decided to copy that comment to the DDE Application Not Running box, and could not detect any ill effects. I also kept the /n and the /dde on the command line, simply because I could find no harm in it.
Uninstall If you try out these suggestions, but they don't work out for you, reverting to the way it was before might prove more difficult than you would expect. It seems the dialog where you make your changes will always append a %1 to the command line when you press OK and it isn't present already. The only solution I could find was using regedit to remove the %1 without using the dialog. The command is stored under the default key at HKEY_CLASSES_ROOT\Excel.Sheet.8\shell\Open\command. If you choose to revert the DDE settins using regedit as well, you can simply remove the whole ddeexec\IfExec subtree.
Feb 02, 2009 | Computers & Internet
HOW DO I REMOVE SMART CARD FROM WINDOWS XP LOGIN
1. Click Start
2. Click Settings
3. Select Control Panel
4. Double click Administrative Tools
5. Double click Services
6. Scroll down and highlight the service you want to adjust
7. Right-click on it and choose Properties
8. Click the stop button.
9. Select Disable or Manual in the Startup Type scroll bar.
Services to Disable:
  1. Smart Card / Smart Card Helper - If you don’t have a smart card system, you don’t need this service. As smart cards have really never taken off… i doubt you need this. Kill it.
  2. TCP/IP NetBIOS Helper service - Unless you run NetBIOS on your system, you don’t need this service. Kill it.
  3. Uninterruptible Power Supply - Although I should have a UPS, I don’t. If you don’t, then disable this service.
  4. Remote Registry service - This service allows one to remotely edit the registry through a network connection. If you are editing your registry remotely, then you are too jedi-ninja to be reading this guide. The rest of us should have this off for security alone.
  5. Error Reporting Service - A program crashes and microsoft wants to know about it. Give up your extra CPU cycles to help Gates polish his OS, or you can just disable it.
  6. Wireless Zero Configuration - Unless you use wi-fi, you can safely stop this service. If you use wi-fi, this is actually a nice little service.
  7. Alerter - This is so useless SP2 turns this off for you. For the rest of you folks, you should turn it off too.
  8. Clipbook - This service allows you to cut and paste across your private network. Most programs that actually allow you to do this use their own ways for doing this.Useless.Stop it.
  9. Computer Browser - If you are on a LAN, keep it enabled. If not, stop it. It allows you to see the other computers on your network.
  10. FastUser Switching Compatibility - If you keep multiple users/logins on your current computer, you should leave this enabled. If you always log-in the same way as the same person, you should disable this.
  11. Messenger Service - Kill it, kill it. We’ve been saying to kill this forever.
  12. NetMeeting Remote Desktop Sharing Service - If you don’t use NetMeeting, you should stop this service.
  13. Network DDE/Network DDE DSDM - DDE DSDM was an excellent idea by Microsoft that flopped. Disable both of these.
  14. Remote Desktop Help Session Manager Service - I use remote desktop all the time. However, you should not have it enabled unless you use it.
  15. Telnet Service - This allows you to use telnet to log into your system from a remote location. It’s a security risk so don’t keep it enabled unless you use it.SP2 disables it by default now.
Nov 26, 2008 | Audiovox Computers & Internet
How can I stop a "DDE Server Window" error message from coming up every time I turn off my computer? I suspect there is something in the regestry that needs to be changed or deleted. If that is...
dear doneb,
"DDE" means Dynamic Data Exchange. It is used in windows2.0 and also used in some places higher versions of windows. So it is not a spyware or malware.You can disable it by followin the steps below.
>Click Start, click Control Panel, click Performance and Maintenance, and then click
>Administrative Tools.
>Double-click Computer Management, double-click Services and Applications, and then
>double-click Services.
>In the Details pane, click Network DDE.
>On the Action menu, click Properties.
>On the General tab, in Startup type, select disable, and then click OK.
Sep 19, 2008 | Computers & Internet
WinXP SP2 not detecting bluetooth device
you have to install windows vista again only to enjoy the full function for the notebook coz in windows xp it won't work i to tried this and had faced the same problem in acer travelmate laptop
Apr 22, 2008 | HP Pavilion dv4000 Notebook
Cannot access internet
It is only internet? can you access files on the server or print from a remote printer?
Apr 09, 2008 | Computers & Internet
Mouse freezes after installation of new graphics card
first update the bios of your system.
Then remove the drivers using safe mode, Download new drivers from nvidai web site ( do not use the drivers on the vga's cd). Disable any antivirus software and try again.
Oct 24, 2007 | EliteGroup V7.5A (K7SOM+ V7.5A)...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
