Question about Sony Cyber-shot DSC-W55 Digital Camera
My polaroid i633 won't work!
My polaroid i633 turns on for a quick second and then the screen goes black and you can just barely see the word polaroid.Also the lens wont go in.
  • TamHanley May 28, 2008
    Same problem as above- lens is stuck "out". Must take batteries out to power down, or the batteries will run down while the camera tries to pull the lens back in (which it cannot). I took all the screws out to open the camera as suggested, but it the side by the tripod screw does not open. Is there a hard reset somewhere, or something of that nature that doesn't require dismantling the camera?
    Problem Solver:
  • 6 Answers
YOur camera is looking for verification that the lens is extending. Once it sees the lens has extended when you power on, the sensors in the lens tell the Operating system that the lens is Ok.
If it does NOT see verification from the lens, it shuts down. Never force your lens back in. You may have to take the camera apart to reset the lens. you do this by removing the Zoom gear drive assembly and free you lens up by hand. 1 grain of sand or grit is like a Monkey Wrench in a Gear cog. Clear the obstruction with a can of compressed air, and work the lens with your hand. once you can that put it all back together and it should work.
Posted on Mar 15, 2008
Polaroid TLX04244B screen goes black after one minute after being turned on.
Failed capacitors on main board.could be dry joints...quick way to find out is open back after disconnecting from mains.look for any swollen..split or burnt capacitors...these are black with silver tops...
tutorials on YouTube....if it's just dry joints then as they warm up the solder joint disconnects thus resulting in shutdown.try tip of solder iron on all the connections that look suspect.usually telltale signs are brown flux seepage and cracked solder around connections.
Jun 06, 2015 | Polaroid Televison & Video
I bought a sandisk 4 gb sdhc card for my polaroid i633 and it says card error why????
Read your manual my camera is only 3 years and won't support sdhc,i have to use a standard 2g sd card.
Mar 29, 2011 | Polaroid i633 Digital Camera
When I hook up my polaroid camera i633 to my pc it won't automatically download my pictures from my camera like it use too. It ask me to Please consult with your device manufacturer for assistance getting...
it may be due to the camera application software which is installed in your system I advise you to uninstall the camera pc suit software form the system and reinstall the application again it will resolved your problem.
Nov 06, 2009 | Polaroid i633 Digital Camera
Polaroid flm 2017 turns on then goes black sound still works
This problem is often replated to a leaking power supply capacitor on the secondary side of psu rated at +/- 2000uf at 12v...yup 4 bucks should do it...the hardest part is often opening the power supply up screws are often located underneath rubber feet....never make contact with the primary ac supply side even after it is unplugged reservoir capacitor high voltage can store a charge for long time and be dangerous to contact.
Dec 13, 2008 | Polaroid FLM-2011 Television
Help my polaroid i633 is not working
Help!! When I download videos to my computer you can barely understand because the sound is all chopped up !!
Feb 06, 2008 | Cameras
Polaroid i633 camera
http://www.polaroid.com/service/userguides/digital/cameras/i633_ug_en.pdf
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Lost USB cord to digital camera
Use a card reader. No battery drain while using the reader hooked to your computer.
You can find them bor between $8 and ????
Good luck.
Oct 24, 2007 | Polaroid i733LP Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
170 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
