Question about Nintendo GameCube Console
Nintendo Gamecube Controller ports
My gamecube won't reconize the 4th controller. I've tried different controllers and it does it to them all. Is there anything special way to clean it or repair it. I have tried acohol and water.
  • Anonymous Mar 20, 2008
    well it does recognize it cuz it will just keep vibrating, not sure what i can do to fix it any suggestions
    Problem Solver:
  • 8 Answers
The controller port could be the problem, and the part is fairly cheap on eBay.
Posted on Mar 24, 2008
Dear jenmelton,
The reason why it doesnt reconize it is that the slot eithier has been pluged or the wires may have been mixed up.....or maybe ...Did you buy the controller in a pawn shop??? If you did the saler gave you a rip off....Otherwise id suggest you go to costomer survice.....
-SuPoRtEr
Posted on Mar 19, 2008
SOURCE:
Wii controller won't work with gamecube game in wii console
Gamecube games don't have the proper coding installed on the discs in order to receive commands from the Wiimote. You'll have to have a Gamecube controller to play Gamecube games even on the Wii console.
Nov 23, 2011 | Nintendo Wii Console
We downloaded Mario Bros (original) on the Wii It takes the original Nintendo controller to operate, but how do we plug the original Nintendo controller into the Wii ???
Original controller as in the original Nintendo Entertainment System (NES) controller? The NES controller is not officially supported on the Wii, however an adapter exists that goes into the GameCube controller ports which can be purchased at RetroPort. The other control methods the game supports are Wiimote (turned on it's side which acts just like a NES controller), GameCube controller, and the Classic Controller. Hope this helps!
Jul 19, 2011 | Nintendo Video Game Consoles & Games
How do you get the nitendo game cube to play on the wii
The Nintendo Wii already comes with everything needed to play GameCube. GameCube disks are loaded and unloaded from the system in the same way that Wii game disks are used. To play the games you are going to need a GameCube controller and a GameCube memory card to save progress. On the top of the system (if the system is vertical) or on the side (if it is laying down) are two flaps, one which opens to reveal the controller ports and the other reveals the slots for the memory cards. To play GameCube, simply select the top left square from the main menu (like you would for any Wii game), select start, and then use the GameCube controller to play the game.
Jul 16, 2011 | Nintendo Wii Console
How do you use a Gamecube controller on the Wii ?
Assuming the Wii unit is situated vertically, look on the top of the unit. There should be two flaps. Lift them, and you will find plugs for four GameCube controllers and two GameCube memory cards. Plug in the controllers and go.
Bare in mind that only a very small number of Wii games actually use GameCube controllers. The controller slots are primarily for playing GameCube games on the Wii, which the Wii can do right out of the box, provided you have the controllers and memory cards.
May 31, 2011 | Nintendo Video Game Consoles & Games
Need instruction on how to get an iconcepts wil/gamecube controller to work on my wii.
  • 1 Gather up any GameCube controllers that you want to use with your Wii.
  • 2 Open up the top of your Wii. If you unhook the latch on the very top of the system there should be a sort of secret compartment that holds four controller ports and two memory card slots.
  • 3 Plug your GameCube controller into the ports located in the top of the Wii. If you're plugging in more than one, don't worry about attaching them in any particular order.
  • 4 Load any GameCube memory cards that you would like to use into the memory card slots located next to the controller ports on top of the Wii.
  • 5 Feed the GameCube game you would like to play into the disc slot on the Wii
  • Read more: How to Use a GameCube Controller on Wii ' eHow.com http://www.ehow.com/how_2107888_use-gamecube-controller-wii.html#ixzz12YTzQXef
    Oct 16, 2010 | Nintendo Video Game Consoles & Games
    Wii blows fuse when inserting gamecube controller
    The obvious answer to this would be.
    That the gamecube controller, is faulty.
    Or the controllers port on the Wii, is faulty.
    Try using a different Controller on the Wii.
    Or try inserting the gamecube controller, Into a different Port.
    Mike @ compurepair.
    Dec 01, 2009 | Nintendo Wii Console
    My nintendo gamecube controller won't work in my nintendo wii
    Are you talking about the controller or memory card?? If the controller try plugging it into the second gamecube controller slot even if you are wanting it for player one. This is the only way I have been able to get it to work.
    May 20, 2009 | Nintendo Wii Console
    Can we play gamecubegames inside the wii console, if so how?
    You can do both. With internet you can download Nintendo 64 games on the wii shop channel. For game cube games enter the controller in slot one, enter the game and it's like you don't have a wii!
    Note: due to the fact the the wii remote does not have enough buttons ALL N-64 games need a gamecube controller or a classical controller. Game Cube games are not compatible with classical controllers.
    Apr 02, 2008 | Nintendo Wii Console
    Wii/Gamecube game
    Yes you can play gamecube games with no emulators. The memory card slots and controller ports are located on top.
    Dec 06, 2007 | Nintendo Wii Console
    Nintendo GameCube Console Logo
    60 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Ekse
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
