Question about SanDisk 4GB microSD High Capacity Memory Card
Write protected removable
When i try to copy write protected comes on
  • 2 more comments
  • Anonymous Aug 10, 2008
    KEEPS CUMING UP WRITE PROTECTED
  • DAVID32 Nov 20, 2008
    WRITE PROTECTED KEEPS [POPPING UP
  • Anonymous Nov 25, 2008
    same. my flash drive is "write protected" I cant remove or add any files.
    **** it
  • Anonymous Feb 21, 2009
    when i try to put songs on my 4gb micro sd write protect keeps on popping up
Hello Everyone!!! I know how it feels when you are in a serious problem and no solution is helpful to you! I have a SAMSUNG SGH E250 and 1GB KINGSTON micRO SD card. I faced the same "Write protected" problem and I searched for this solution and didnt find a good one! NO SOLUTION HELPED ME!.. First of all I would like to tell all the Solution Submitters that micRO SD card doesnt have a switch on it but its adapter have it. I know those who have card readers can put their Cards in the adapters and slide the lock downwards (or to opposite direction) and after that they can put that adapter into Card reader and the problem will be solved !!! But this solution is for those who doesnt have card readers !!!
SOLUTION TO THIS PROBLEM:-
1. Put the card into the slot of your mobile and connect it via USB cable to your PC.
2. If you do have a driver CD of your mobile then install all the drivers.
3. When you are done and can see the card as "Removable disk" on your PC then Go to Tools in Top ( File, Edit, View, Favourites, Tools, Help) Then Folder Options - View - Show hidden files (tick on the Show hidden files) and also tick on the "Show system hidden files (This is important). Then Apply - OK...
4. Open the Removable Disk (Your Memory Card), You will find a hidden system file. Just delete that file with some special softwares (manual deleting will not let the file delete coz its write protected).
5. Try to copy some file in it, if it allows you to copy then CHEERS!!!
6. If not then reformat it with your mobile phone..
Actually I accidently did the same steps and deleted the esamsung something file and I SUCCEDED !!!
Same applies with All USB pendrives and Memory Cards...
HOPE IT WORKS FOR YOU !!!.
IF NOT THEN LET ME KNOW YOUR PROBLEMS IN DETAIL AND MAIL IT ME at [email protected].
I WILL FIND A SOLUTION FOR IT..
THANXXXXX
Posted on Jan 28, 2009
I have searched all over the internet looking for a solution to the "write protection" removal process, and the only thing that I have found out, is there is a vast amount of morons out there that call themselves problem solvers who haven't got a clue as to a solution to this problem. NO! The card doesn't have a switch on the side of it! Trying to format the card doesn't work! Pulling the card out of the reader while the card is being read... Really dude? I mean.... How'd this genius come up with that remedy? Wow!
I have a PSP that came with a 1GB MemoryStick that gave me the same BS message. When I tried to go through Sony I was given the run-around. The solution to this problem is, get a pair of wire cutters, place MemoryStick in between the blades, then firmly squeeze down on the handle of wire cutters. Place the severed MemoryStick in an envelope and mail it to sony with a letter of complaint. (Although the use of expletives is unnecessary, they are highly encouraged.) When enough complaints are received by Sony, perhaps they will provide an actual solution to this problem.
Posted on Jan 07, 2009
  • 979 Answers
Much more info please!
Posted on Mar 15, 2008
SOURCE:
My bluray player in my acer comes up with a "cannot play right protected content" when i try and play a bluray dvd in my bluray player
if that is a copy of a blu ray movie you are trying to watch... when the copy was made the copyright protection was not removed before it was recorded.
Aug 19, 2010 | Acer Computers & Internet
Conveting old VHS-tapes to pioneer 645h-s
you can get software for your P.C. to upload to the pc and burn to dvd(i assume that is the desired end product) Most come with leads.
www.cyberlink.com
www.magix.com
www.nchsoftware.com
try these sites for your needs
Mar 05, 2010 | Televison & Video
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
When trying to play dvd message comes up dvd copy protected
the dvd copy protection message is annoying but just to inform you that the DVD cann't be copied without special software that breakes the code. such as clone dvd.
Nov 06, 2009 | Intervideo WinDVD 5 for PC
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
Write protect
Well it is kinda hard to do. There are multi million dollar companies trying their darndest but every time they think they have it licked, someone finds a way aroud it.  Even if you do find a way to protect the cd as a whole then someone can come by with a program like clone cd and copy the whole thing protection and all.  Im not trying to be a downer just telling you the truth.  I think your better bet would be to copywrite the music. this way if someone does copy it you have a legal avenue to take.   Now Im not sure what contry your in but in the us I would start here.
http://www.copyright.gov/
Then find the correct form for hardcopy or go the online route if applicable, send the song or compilation, send money, wait a long time, you will get your copyright.
but if you are dead set on protecting your music then there are programs out there that will do it like
http://www.inspyreit.com/2008/10/how-to-copy-protect-your-cd/
ive also heard there is a program that is called CCDLock that worksd in conjunction with cloecd that may do what you are looking for, but like i said before even if you do get it to copy protectce the cd any 12 year old with a computer and an internet connection can download a program to overide the protection.
Sorry to be such a downer and all, I myself am a computer programer and understand wanting to copy protect your intelectual property but I also realise Piracy is a fact ofo life in my line of work and there is nothing I can do to stop it.  So i just try to make my product so appealing and affordab;r that people pay for it to help support it and dont even try to get around it.
Hope this helps a little.
Dec 08, 2008 | Computers & Internet
VR5940 DVD Recorder/VCR-Thinks a regular VHS tape is copyright protected
Don't know your machine, but is it possible that it's seeing your source tape as write protected (missing tab) and so assuming it should not be copied to the DVD?
Jun 14, 2017 | GoVideo VR5940 DVD Recorder/VCR
False write protect on an EMPREX 8GB Flash Drive
hiii martin....
dis type of problem comes when sm files inside d folder which iu want to copy restricted allowing files to copied...
u can copy it by fallowing procedure....
first open urs folder and select some of urs files not all of them and copy it to flash drive by makin a new folder....and similarly copy other files in that new folder..
if u do like that u can copy all files eaisly......
if it creates ore problems ask me.......
also available for live chat....
thankss
Jun 20, 2008 | Electronics - Others
Canopus ADV c110
It sounds like the DVDs are protected by Macrovision copy-protection. The ADVC units are not designed to bypass Macrovision copy-protection.
Sep 25, 2007 | Canopus ADVC-110 A/D Converter...
Copy Protection Signal
"Copy Protected Signal." Means that the data you are trying to Ahem... "Copy" probably has copy protection inbuilt into the disk & data. This is done to stop copying of pirate DVD's etc. Part of the DRM put out by the TV/Music/Film industry. There are programs that can strip protection and enable one to copy said DVD's.. AnyDVD is one that springs to mind, as does Dameon Tools, and many others simply Google for them.
Jul 11, 2007 | Panasonic DMRES15 DVD Recorder
SanDisk 4GB microSD High Capacity Memory Card Logo
353 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
