Question about Dryers
Help My dryer would sometimes stop heating the cloths, Now there is no heat at all.
    Problem Solver:
  • 16 Answers
Is it electric or gas.
im gonna go with it being electric on this run. if so, most causes are the heating element. they just break due to just being worn. you can only heat for so long. and even not so old units as well.
they are simple to replace or you can get a qualified tech to do it.
now if you have a gas dryer. and its specifically the heat. you may want to take a first look at the high temp switch on the unit. there may be more than one but the most common is right on the exhaust vent along the back. they are usually held in with two screws and its about size of a brachs wrapped mint candy including wrapper (haha good reference) however it dont taste the same. jk.... take this switch to a parts store for washers/dryers and ask them to test it. they are not to expensive and usually are the issue. all they do is function as a safety switch when you unit gets too high on temp..then the switch cuts out the gas supply. the fail in the open position..not allowing signal to go through..simple class ehh..
well gl
K.
Posted on Mar 15, 2008
  • 26 Answers
First thing I would check is the plug in , is it burnt or discolored? Might have been loose and worked on and off . Could be thermostat , timer or wiring.
SOURCE:
Why does my gas dryer heat keep shutting off?
The solenoid coils on the dryer are acting up. This is a common problem. They work a little then heat up and short out. Easy fix I did some videos:
How it works
Replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer stopped drying cloths cleaned out vent still will not [email protected]
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 27, 2011 | Whirlpool Dryers
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
Dryer stop getting heat....doesn't completely dry cloths
heatman101
Dec 20, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Model no. mdg3000aww Sometimes the gas will turn on to heat but will stop before the cloths are dry. Then there are times when the gas will not go on.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Maytag Dryers
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer has no heat. Tested some of the fuses and they test good. Is there a way to test the igniter with a multimeter?
have you checked the dryer vent that goes through the outside wall sometimes the outlet gets clogged up with lint and the heat will recirculate instead of venting outside, the recirculation somestimes tell the dryer sensor that the clothes are dry and will stop sending heat to the dryer or very little heat clear the vent and see if that helps also check the pipe at the bottom of the dryer they sometimes clog up as well if no sucess call a gas appliance repair service you do not want to fool aroud with gas appliances re igniters or where burners are concerned
Jan 09, 2010 | Whirlpool LGR5636L Gas Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
