Well the screen is dead and the emachine splash is dead
so screen triple dead if BIOS is dead, so we fix that first.
here are the tests in order correct.
and quadro dead, fans dead.
All uSB devices unplugged. DVD tray EMPTY for sure does button eject work if not power is failing. to DVD drive.
1: remove the huge battery first they short and overload the PSU power rails and VRM inside the PC , just remove it.(easy no?)_
2; then use only the AC to DC power pack for power, even for ever.
let me be clear run on AC power only.
3: screen wake up yet? a goal best BIOS screens up.
4: the flashlight test is next to any black screen , pc seems on.
I can hear HDD spin ear to casing of hdd, hummmm
5: still dead screen? out the hdd, remove it and DVD drive both
as those to can short, in fact up to 20 things in a PC can FAIL.
6: the coin cell above 2.9vdc and never below, 3.3vdc new.
CCLF DEAD.
7: strip the PC down more, in you mind focus on modules and device that can short, even to to 1 stick of DDR memory, AC power cord pull do not remove things inside any PC with AC power to wall jack, ever, and big battery is already gone until PC runs right again,.
2009 MADE NEW. CCFL INSIDE !!!!!!!!!!
emachines eMachines W4620 (M622-UK8X)
SOURCE: Bad Battery on EMachine M622-UK8X?
Pull the battery and try powering on the laptop. If it comes up without any problems, it is probably time to invest in a new battery if you want to continue using it as a laptop.
SOURCE: emachine M622-UK8X won't power up. When plugged in
no power to laptop have battery disengage and still will not come on
SOURCE: Have an emachine laptop m622-uk8x. The power
first you have to get a part number for the switch. Call E-machines and explain your situation. They can look up part number and order it for you.
if you os is still trying to boot...power on/f8 safemode with networking or without networking and if windows starts up, then go system restore before the day you had the problem.
