ASUS ALi Chipset A7A266 (A7A226) Motherboard Logo
Posted on Mar 15, 2008
Upgrade the video card
I have asus a7a266 motherboard, 1.01ghz amd 1g memory.
64m apg video card but the image is soo slow. i bought 128 mb of pci
e-geforce fx5200 but anytime i conect the fun comes on then immediately everything goes off. please can you help me.
thanks Soli
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Mar 27, 2008
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
13840
Points
57
I think your power supply unit (PSU) cannot deliver enough power to cater all the devices in your system. Replace with a new and higher rating of PSU.
1helpful
Will an ati radeon 9250se graphic card be compatible in an emachine d2244 computer? there are two empty pci slots on the motherboard above the one that has the phone and modem conections. i have upgraded...
I am presuming you have XP on your computer.
According to ATI, this graphics board should work fine in a spare PCI slot.
Install in the top PCI slot as your CMOS detects top to bottom.
XP should detect the ATI board and will ask for drivers.
Install your CD drivers and or software as needed.
If you have VIsta or Windows 7, it does not appear ATI supports them for drivers.
Good Luck
http://support.amd.com/us/gpudownload/Pages/index.aspx
Please help, need drivers! ACPI x64-based PC Microsoft Windows 7 Ultimate Processor: AMD Sempron,1800 MHz (9 x 200) 3200+ Motherboard: Foxconn K8M890M2MA Series (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2...
This sounds like one of those store bought computers - Dell, HP, Asus, Acer, etc - is there a brand and model number available if so - these sites will have all the drivers for the particular model.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Added 1G memory, for a total of 2GB. the system still only sees 1G
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory. You can check below URLs for reference:
http://dlsvr.asus.com/pub/ASUS/mb/4GB_Rev1.pdf
hope this helps
Grapghics card or ram?
No need for extra memory, your onboard video card is truly ancient- replace it with the best PCI-E video card you can buy.
One like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131359
ASUS CUSI-M ACPI BIOS Revision 1007 run very slow when i wana use 1024 by 768 pixel.how i can solve this problem.my processor speed is 700 MHz. 2.is it possible AMD 1.3 processor connect with this...
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
1helpful
Want to upgrade video card
That depends on
What kind of slots you have.
Many vendors don't sell old products.
Find out what type of slot u have ie (pci) is it white or black?
When you know, that will be key to finding who has your card.
You may want to call a vendor to avoid taking a trip to find they dont carry
the older video card slot types.
If you find one, most old cards have a great price.
I have the P5GD1 in my ''Fujitsu Siemens Scaleo P
Depends, increasing the memory will speeds up the system overall. However, you are using slide shows photos, rendering video which will slow down any system that uses a graphics card with slow memory on it or too little memory. It may be an Asus MB but it was made for Fujitsu. The motherboard does have a PCI-E slot. If you increase you're memory to 2GB and install a fast PCI-E graphics card with 512MGB of DDR3 memory you're system will run much faster.
http://www.nvidia.com/object/product_geforce_9800_gtx_plus_us.html
The next video card is a bit slower than the one above. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410186&CatId=1826
Cheers'
Mike
2helpful
6answers
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
1helpful
2answers
32 mb ATI Rage 128 Ulta upgrade
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101565
The documantaions say thar you have an APG-port, i cant see any problem why you couldent upgrade it...if u can find a card.
Good luck
Upgrade motherboard?
Hello Keith,
The present Motherboard in your computer is Asus A8AE-LE. It has a lot of upgradign options.
It will support the Following CPUs.
Up to AMD Athlon64 X2 4800+
Up to AMD Athlon64 4000+
Up to AMD Sempron 3200+
Also, it has the following memory specifiations.
Memory Installed 1 GB (2 x 512)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
Speed supported PC-3200 MB/sec
Type 184 pin, DDR SDRAM
DIMM slots Four
Open DIMM slots Two
And the PC has a PCI Express x16 slot you can install a high end Video Card along with a power supply upgrade.
So before you go ahead with replacing the motherboard I would recommend you to consider these options as we can cut down the cost to a greater extend and having the same iprovement on performance.
If you wish to upgrade the motherboard you can use any motherboard having ATX form factor [9.6 in X 9.6 in] in the computer. The CPUs should be selected according to the motherboard you have chosen.
Hope this helps
Pat
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
