Question about Acer Aspire 3690-2196 Notebook
Forgotten Password need help to unlock my laptop I forgot my password
  • 5 more comments
  • kldr Mar 15, 2008
    win XP
  • kldr Mar 15, 2008
    yes my windowsXP
  • kldr Mar 18, 2008
    No this did not help me at all I had to take it into Best Buy and pay another $29.00 to have them unlock it. Wish I had never gone through FixYa.
  • snake29 Mar 25, 2008
    I forgot my password to unlock my computer. I have an acer 3680 notebook.
  • pretty36 Jun 20, 2008
    lost pasword to acer aspire 3680 can you email me download to restore.
  • ruby2008 Dec 18, 2008
    have windows vista and have forgotten my logon password how do i get around this as i dont have a disk or floppy
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    I assume we're talking about your logon password? Are you running Win XP and do you have your Win XP cd?
  • 667 Answers
Good.
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repai...
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account. Just in case your laptop isn't set to boot from cd, it probably is, you just have to go into the BIOS and make sure sure that the cd is is set to bootable and it is set to boot from cd before your hard drive. Try it with your Win XP cd first and if it doesn't work and you don't know how to go into the bios and set it, add another comment and I'll come back and tell you how to do that. This looks long and involved but it doesn't really take that long. Good Luck. If I helped out rate me a big 4 Fix Ya. Let me know how it turns out. Thanks for using Fix Ya.
Posted on Mar 15, 2008
SOURCE:
SOURCE: forgotten set up password
no it didnt worked its not bios password its set up password n it comes in dell insprion 6400
Posted on Feb 09, 2008
  • 9 Answers
SOURCE: Gateway Laptop forgotten password operated by wINDOWS Vista
well, i am regret to hear this. since the gateway password is the most secure password, in my opinion ,you can only contact the supplier of the laptop.they can offer the service that resume the system normal and make the assurance the data wonn't lose.
Toshiba laptop battery
Posted on Jun 18, 2008
sys_admin
  • 829 Answers
SOURCE: forgotten password on hp laptop
How to create a password reset disk loadTOCNode(2, 'moreinformation'); Note that this procedure requires one blank, formatted floppy disk.
To create a password reset disk for your local user account, follow these steps:
  1. Press CTRL+ALT+DELETE. The Windows Security dialog box appears.
  2. Click Change Password. The Change Password dialog box appears.
  3. In the Log on to box, click the local computer--for example, click Computer (this computer).
  4. Click Backup. The Forgotten Password Wizard starts.
  5. On the Welcome to the Forgotten Password Wizard page, click Next.
  6. Insert a blank, formatted disk in drive A, and then click Next.
  7. In the Current user account password box, type your password, and then click Next. The Forgotten Password Wizard creates the disk.
  8. When the progress bar reaches 100 percent complete, click Next, and then click Finish. The Forgotten Password Wizard quits and you return to the Change Password dialog box.
  9. Remove and then label the password reset disk. Store the disk in a safe place.
  10. In the Change Password dialog box, click Cancel.
  11. In the Windows Security dialog box, click Cancel.
Posted on Feb 02, 2009
SOURCE: lenovo master password forgotten
i own one too, and only way to fix that is to reset the BIOS, i mean is the battery removal.
Posted on Jul 04, 2009
athulnair
  • 101 Answers
SOURCE: I have forgotten my laptop bios password
  • Just remove the BIOS battery from your system.
  • Then reinsert the battery.
  • Password of BIOS will be reset.
  • That is the way to reset the password.
-rate if it helped you.
Posted on Apr 07, 2010
How to unlock
Deb, You may have to do a factory reset if you can not remember the password. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot your tablets password
Forgotten Pattern PIN or Password on an Android device
What do do if forgot my password to unlock to my tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
May 20, 2016 | Tablets & eReaders
Bought a laptop at auction but don't have password to open up
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded · How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Feb 11, 2016 | Gateway M320X Notebook
    Forgotten password on hp compaq laptop
    Forgot password on your hp laptop? You can try with a Windows password recovery tool - Windows Password Unlocker, which is efficient for you to reset the forgotten Windows password with a bootable CD/DVD/USB.
    Oct 24, 2012 | HP Compaq 6735s Notebook
    Forgot password for administrator account
    Use windows password reset tool is the best way to recover admin password.
    Here are three tools for you.
    Windows Password Reset( http://www.windowspasswordreset.net )
    Windows Password Recovery Tool ( http://www.windowspasswordsrecovery.com )
    Windows Password Crack( http://www.windowspasswordcracker.com )
    Jul 30, 2012 | MSI Wind UmNotebook
    My labtop is locked
    Unlock Windows password with Windows built-in Administrator account.
    Here's how this admin unlocks forgotten Windows password:
    Start your computer and wait for the Windows Login or Welcome Screen. Once it shows, press Ctrl+Alt+Delete twice and then type Administrator in the pop-up username box, but leave the password column blank. Next you could successfully log onto system. The following steps for resetting the forgotten password are quite easy. You can make it from "Start->Control Panel->Users Accounts".
    Besides, Windows Password Reset is a great choice .
    Jun 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
    Lahow to unlock the ibm pentium 3 laptop that need a password?
    The experience forgot computer password happened to me few days ago. And I searched on the Internet to find the solution. Then I found a windows password reset tool called Windows Password Recovery Tool have a good evaluation.
    I tried it as the steps:
    Step1:Download and install Windows Password Recovery Tool
    Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
    Step3:Put in my newly created CD and remove my forgotten computer Password.
    It really great help to me hack computer password.
    Hope it help you too!
    Jan 24, 2011 | IBM ThinkPad T20 2647 Notebook
    Forgot privacy password on Samsung Genio Touch S3650
    i hav samsung corby pro GT b5310 model I had my password set on my message but i forgot the password now so please help me to unlock the password...If u hav any idea to unlock then please help me......
    Apr 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
    I forgot my password so how can i unlock my laptop
    Forgot laptop password? Hack password with Windows Password Recovery Tool 3.0! http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
    Feb 23, 2010 | Computers & Internet
    Gateway Notebook NT3707- forgotten password operated by Windows Vista
    the is only one solution, you have to have a program that will unlock the computer, I use a probuct here in my shop called Spotmau, that unlocks passwords, there is another method u might try first before you take it to a shop to unlock it, in the password dialog box type in the top admin, and in the password line type owner, that is the way gateway set their systems up to unlock the passwords when forgotten.
    any further assistance you can send me a personal message and i will respond as soon as I get, I'll be glad to help in anyway I can.
    Dennis
    Jun 16, 2008 | Computers & Internet
    Acer Aspire 3690-2196 Notebook Logo
    214 people viewed this question
    Ekse
    Alun Cox
