Question about Nikon Coolpix L14 Digital Camera
Self-timer light stays on
I admit to being the source of the problem; I drop the L14 in the ocean. I requed it quickly, and although it was on when I dropeed it, I took the batteries out immediately in the hope of saving the camera. I waited a few days for it to dry out, and then tried turning it on - and it actually came on! It let me set the settings, and even take a picture, but the self-timer light on the front remains on. It even remains on when the camera is off, as long as I leave the batteries in.
Also, the camera returns to the menu (the one that is accessible from by pressing the button over the screen, which changes between portrait, close-up, etc.) without my pressing the button. It looks like there is some salt or sand in the crevices around the top, and I wonder if there is a connection.
    Problem Solver:
  • 6 Answers
Salt Water is like the Acid in a car battery...once you drop a camera in the ocean its basically Done! Salt water is a conductor of electricity and will short out parts of the circuit board(s). The best thing you could have done was take it apart and have the circuit boards Sonically cleaned by a jeweler or a place that has the capability to sonically clean electronics. This involves Total disassembly of your camera however. Sometimes its not worth it.Sounds like you still have some salt residue inside the contacts that tell the camera that the self timer switch is "made" or Shorted.
Some CRC Electronic cleaner may work as well...thats the easiest solution. Take it apart and Drench the boards, Contacts with Electro cleaner. Thats where I would start if you can remember how to put things back together.
Posted on Mar 15, 2008
My canon 70d does not zoom and focus automatically
My guess is the self timer was accidently turned on
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 02, 2017 | Canon Cameras
Turn off night lights and have no lights on during the night
The blue lights imitate moonlight over the ocean. Those lights are there to better imitate the fish's natural environment, which is almost never completely dark.
Feb 14, 2014 | Oceanic Coralife Digital Power Center -...
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Solution
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
Attention:
NOTE:
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
S3300 nikon was dropped and now doesn't do anything but show the on light.
It seems rather apparent that you broke your camera when you dropped it. Since you publicly admitted you dropped it, Nikon isn't likely to cover it under warranty. It looks like you need a new camera...
Sorry if that wasn't the answer you wanted but if you break it, you buy it.
Dec 09, 2013 | Nikon Coolpix S3300
Ford focus 1.8tdci glow plug light only staying on for about 1sec in sub zero temperatures
When this problem occurred this usually means that one or more of the engine glow plugs is burnt out, the decrease in resistance sensed by the glow plug controller drops and this causes the timer to turn off to quickly, have the glow plugs tested and the glow plug controller replaced if needed.
Nov 30, 2010 | 2004 Ford Focus
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
We cannot get our timer to work. It keeps displaying no O P.
It's the simplest possibility, but do you happen to have compact fluorescent light bulbs in the light? They are not usually compatable with timers.
Jan 10, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Dropped in ocean. Can I recover the data ? Or video ?
if the card hasnt been comprimised, yes. most SD and Xd cards are sealed from the elements. do it quickly however. time is of the essence
Dec 24, 2008 | Pure Digital Flip Video Camcorder
How do you turn on self timer on a konica dimage z6
Okay - I felt like an idiot but the instruction manual sucks for this!!!!!! Press the menu button and stay on the first screen - Drive mode will probably say single and have image information listed under it. Use the down button and highlight drive mode - press the right button and it will change to single and under that it will say self-timer. Now use the down button and highlist self - timer and press the enter button. Now you use the self-timer. Once you take a picture, the camera will revert back to single image, it will not stay in self-timer mode, so you have to go this process everytime to use self timer. Hope this helps and happy picture taking!!!!!!!!!!
Nov 18, 2008 | Konica Minolta Cameras
Nikon Coolpix L14 Digital Camera Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
