Question about Samsung HT-Q70T System
HT-Q70T Static - Touch volume knob and now main system display panel doesn't light up and unit doesn't turn on at all. Will not even let the CD's in there be removed. Is there a way to re-set? Looks like a serious problem. Thank You Steve
  • Hello2008 Mar 15, 2008
    Ron, Unpluged for 24 hours. Pluged the unit back in and Stand By Button Light comes back on, but that is all. No change. Held down the power buttom for five seconds that was recommended in the factory manuel, that didn't work either.
    Hello2008
    Thank You
    Steve
    Comment by Hello2008, posted on Mar 15, 2008
    Hello2008
  • 46 Answers
Hello..have you tried to disconnect ac-cord ?..than wait a few minutes and reconnect ?...try this......good luck ron...
Posted on Mar 15, 2008
Volume turns down by itself until it says VOLMIN
I have a Samsung home theater system model HT-D6730W. I have had some issues with the volume turning itself down till it says volmin. I've seen that I'm not the only one with this issue!!!! I have tried all the suggestions that were posted. Doing a hard reset, changing settings, I bought a cooling pad for laptops Hopi g those would fix it. I called Samsung support Which was a joke!!! I took the putter cover off and cleaned all the dust from the unit, removed batteries from remote, removed all cable connection on the back of the unit other than the HDMI cable going to the tv. Having done all that the unit was still turning its self down. I'm a bit of a tinker and so while the cover was off of the unit, displaying all the delicate stuff inside, I turned on the home theater system and played a movie set the volume to a good listening sound. When it started to turn it self down I remove the wide wire ribbon from the main circuit board going to the touch panel on the front of the unit. Voila!!! Sound quit going down!!!! I unplugged unit and removed front touch panel and cleaned all dust from the inside of it. Put it all back together. Tested. Still doing it. Removed the touch panel again and this time I disconnected the small wire ribbon for the volume touch buttons. Reassembled and tested. NO MORE ISSUES!!! Everything on the front still works other than the volume buttons. You can still change the volume using the remote!!!! I hope this finds everybody that is having this issue with there unit.
Feb 14, 2014 | Samsung Audio Players & Recorders
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Volume doesn't work on bose radio in car all the time
Sue,
I had the same issue with a car I owned and had to replace the unit.
May 04, 2017 | 2009 Nissan Rogue
HOW TO VOLUME the speaker even if the volume is 100 already.why is it low?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hop this helps
Nov 11, 2012 | Lenovo Computers & Internet
The display shows all the icons of the sytem and wont clear...
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Jan 09, 2008 | Samsung HT-X50 System
HD QUESTION
stop the dvd and press and hold the sd/hd button.
Dec 12, 2007 | Samsung HT-Q70T System
Power on and Get the Display panel lights up like christmas
That is an internal fault, with it's power supply. They shutdown if an in-balance is detected.Also check the speaker wire connection - will do the same thing if disconnected or shorted.
Nov 01, 2007 | Samsung HT-Q70T System
Samsung HT-Q70T System Logo
60 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
