Question about Bosch 23 in. SHU33A Built-In Dishwasher
Water Pools up in the bottom of our Bosch Dishwasher
After some time of not being used, Water pools up in the bottom of the dishwasher. The dishwasher runs fine.i find that the problem stops when the water is turned off. I was told it could be the valve that needs to be replaced how does one do that without calling someone who wants to charge hundreds of dollars to fix it. Our machine expeiences no other problems. thank you Matt
  • j_wlk_r Mar 15, 2008
    The water that pools up on the inside is clean and does not smell, I do not have a detailed service manual so any kinda how to go about fixing it would be great,
    Sergeant:
  • 351 Answers
The way i find a valve on a machine ive never seen before is to follow the inlet hose to the machine then see if the base comes off or the back panel,its either at the back or at the front underneath.hope this helps.
Posted on Mar 15, 2008
    Genius:
  • 3,587 Answers
Sure...did you clean out the bottom filter too? the valve is buried inside that machine...you'd need a detailed service manual to perform this work.
SOURCE:
Ph level is at 'ideal' chlorine level is at 3.0 but the pool water is still cloudy. Please help?
The cloudiness could be suspended particles or algae. Use an algae k i l l er as recommended, then a flocculant (water clarifier) as recommended, then vacuum the pool bottom and run the filter overnight.
After that check the ph, alkali level, chlorine level, and adjust as needed. That should do it.
Feb 05, 2017 | Pool & Spa
Water collecting at the bottom of dishwasher, used it for the first time and there is a big pool of water at the bottom of the dishwasher when i open up the drawer
Your drain might be plugged. Check the bottom drain. If the water has no where to go, it will fill the bottom up. There might be a cap since it is new. It has to have a place to drain.
Feb 16, 2011 | Electrolux 23 in. ESL6114 Built-in...
There is a pool of water in the bottom of the dishwasher...just bought the house, no idea what the problem is....draining issues?
the filter in the bottom of washer iss full of crud.. it pulls out so you can clean it.. do this and get a bottle of dishwasher cleaner and run your washer on a hot cycle with just the cleaner in and it should be fine afterwards
Dec 14, 2009 | GE Dishwashers
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
Aug 30, 2009 | Dishwashers
Water remains at the bottom of the dishwasher
some dishwashers have water left after the final rinse. it is important to keep the motor seals wet between loads. My filter is always immersed. If we go away for two weeks, I put 2 litres of water into the tub and let it soak 24 hr so that I never start it with dry seals.
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Water pooling on bottom of dishwasher
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Feb 20, 2009 | GE 24 in. GSD4320Z Built-in Dishwasher
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwasher builds up stinky water in the bottom between use
you are back flowing waqter from your drain into your dishwasher make sure your drain are not clogged check your p trap to see if it clogged
Dec 11, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
Bosch 23 in. SHU33A Built-In Dishwasher Logo
133 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
