Split system wont cool
I have installed a 5.9kw nec split system air condiner, electrically correct, pipes lagged and connected. what happens if i turn it on without a vac down?
  • 241 Answers
Check your service valve if open, check for kink piping or system clug up. But check also your refrigerant charge if adequate.by monitoring the suction pressure and current reading.
Posted on Mar 15, 2008
SOURCE:
Error e7 gibson air condination
Condination, wow that is an interesting spelling of the word Air conditioner.
Jun 23, 2017 | Gibson Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
We are installing a kelvinator ksv70hra split system air conditioner. What size pipes does the electrician need to install?
If the installation is not done by an experienced AC technican who does not know the size of the piping , I would not recommend you to proceed further as you might end up with a faulty installation. Please get this work done by a person who knows the subject or else the pipe connections and fittings may not be good enough to prevent leak of the gas thereby reducing yourr efficiency and reduce cooling.
There is more to this than just fitting the pipes and I advice you follow them wisely.
Nov 03, 2010 | Heating & Cooling
Compressor motors are constantly grounding each time the compressors are replaced. A new run capacitor is installed with compressor. A thorough cleanup and evacuation is performed with each compressor...
dear sir
please make sure your electrical connection to the compressor is correct and tighten. electricity supply is straight and not fluctuate i mean constant supply for unit and then change new run capacitor and make sure ground wire must connect to the air conditioner,s body and check copper filter and any other copper pipe is not block .
i think it cab be an electrical problem so check all electrical device and then re-install new compressor.
thank you
hope answer the question
please vote!
Oct 02, 2010 | LG LS180HE Split System Air Conditioner
Car temp went up air condination blew hot while stuck in traffic but once traffic moved everything was fine again
Your electric fan for the radiator is not working. When sitting in traffic you will need the fan for air flow which cools the radiator and air conditioning condensor. When driving fan is not needed do to air flow from driving.
Mar 19, 2010 | 2006 Hyundai Elantra
Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Jan 09, 2009 | Heating & Cooling
NEC split A/C is not cooling for me
if your outside and inide units are running and your tstat has fresh batteries and your air filter is fresh then I will need more info to help solve
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
