Connecting a wii to a RCA Scenium
Seems like input ports 1, 2 & 3 (red, yellow, white) will not work to hook up the nintendo wii to the tv set. The cables are good, because they are hooked to another set at the moment and 8 fifteen year olds are playing super mario smash brothers on a tiny set. The input port 4 works and the x box 360 is plugged into it and working fine. Does the tv have some sort of fuse which makes the first three ports function? Are we able to repair it?
  • 667 Answers
Sorry but I have to ask, are you sure the cables were plugged in correctly on the bigger set? Try using your tv's input button to scroll through the different inputs until you come to the one where the Wii is plugged in. You can check which one by looking where you plug the cables in. i.e. line 1, line 2, component 1, etc. Hope this helps.
Posted on Mar 15, 2008
6ya staff
SOURCE:
Can not hook the TV up to the Wii, it won't come in, I have a new RCA TV . The back of it has a orange color pug in not a yellow and I pug it in and I also don't know what setting to put it on
A newer TV may mean that your wii is not setup to use the proper resolution(HDTV). Are there 1, 3 or 5 RCA ports on the back of your tv?
Some tv's have more than 1 set of RCA ports..are there no ports on the side of your tv? If so, try those instead.
If you have 5 ports only, you may need to use the green one for the yellow cable. This might result in a black & white image, and will be used purely to change your wii settings to use a higher resolution.
OR try this: Nintendo Customer Service Wii No yellow video AV input on your TV
Sep 17, 2015 | Nintendo Wii Sports Resort
Connecting wii to Sony bravia tv
If you have an old V.C.R that has Red, White and Yellow sockets for AV and it still works then plug it into the RF socket tune the V.C.R to your TV and connect your Wii to the Red,White and Yellow R.C.A connections and you should be playing in no time. I have done this myself on a new Samsung TV it will work. If you have no V.C.R and you have HDMI sockets in your TV you can buy an adapter to convert the existing AV port on the Wii to HDMI then simply connect a HDMI cable (if you have 1 if not they are cheap enough off eBay starting at $6.00+AUD or around $20.00AUD Retail) to the Wii and then the TV ensuring that both the TV and the Wii are powered down prior to connecting any cables at the back. The HDMI Adapter for Wii is available on eBay from $5.00 AUD to $24.95AUD depending on the country you purchase it from. If all else fails a second TV with Red, White and Yellow RCA plugs will work but also the most expensive of the fixes. All fixes suggested will work. Good Luck I hope this helps.
Jan 12, 2013 | Nintendo Wii Video Game Consoles & Games
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
Where do I hook up the red, yellow, and white chords to the tv for my wii console to work?
The yellow is video, and the red and white are for audio. All of the ports on your TV are labeled in some fashion or another. Start with the video. You're looking for an "in" port. It will say something like "Video In" or "RCA In" or "Component In". It doesn't really matter how it's labeled, just look for a yellow port marked "in".
You'll then do the same for your audio. Find a red and white port that are right next to each other, and labeled "in". Once they're all plugged into the "in" ports, you'll have to switch your TV to the correct input. It should be something along the lines of "AUX 1" or "RCA 1" or "Video 1", something of that nature. The way you'll know for sure is to make sure your yellow plug is in the yellow "in" port, ensure your Wii is turned on, then keep switching your TV's inputs until you see your Wii's menu.
Jul 17, 2011 | Sanyo DP46848 LCD TV
How do i connect my nintendo to my samsung led tv
I am assuming that you are talking about a Nintendo Wii.  When you buy a Wii it comes with standard RCA composite cables that are three colors, Red, White and Yellow.  Yellow is the cable that carries the video signal and the red/white carry the stereo audio signal.  You would need to connect these cables into the corresponding color inputs on your tv.  Plug the yellow ended cable into the yellow jack on your TV and do the same for the red and white cables.  After this is done, you will need to switch your tv's input to the input that corresponds to the one you plugged those cables into.   Some newer flat panel TVs do not come with RCA composite inputs.  If this is your problem, you will need to get some component cables for your Wii.  These cables look identical to RCA (composite) cables but come in colors red, green, blue, red and white.  In this case the red, green and blue cables carry the video signal and the red and white carry the audio.  You can purchase these from just about any store that carries the Wii or online from places such as Amazon.com.
http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
You would hook these up the same way by matching the colors and then changing your tv to the corresponding input.
Hope that helps!
Jun 27, 2011 | Computers & Internet
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do I hook up my Wii Console to my new Emerson
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
Dec 22, 2009 | Nintendo Wii Console
Wii menu and all sports in black and white; how do we get color?
You are probably plugged into the wrong RCA slot for your Wii's configuration. If your TV is an HDTV you need to either go to your Wii's settings and change the TV settings to HD or remove the Wii RCA (Red/Yellow/White) from the HD slot and put them in the standard input RCA slot. Red/Yellow/White insted of Red/Green/White.
Dec 21, 2009 | Nintendo Wii Console
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
Game console
Should be yellow,red and white a / v inputs on front of tv =
hook-up there and select that input number.........T.
Nov 17, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
