Ipod 30GB HELP!!! My ipod has  been flashing for over 24 hrs now.  The click wheel is unresponsice, and the screen reads: SDRAM Full Test                                                         RUN:    BL on                                                        PASS: BL blink                                                        FAIL:   BL off                                                        Reset to continue ....but how do I reset if the click wheel is unresponsive?  THANK YOU ! To whomevr responds        From Nia
  • shan1511 Dec 25, 2008
    My ipod seems 2 b stuck @ the main menu. wheel wont click, wont turn off nothing worx!!!
    Problem Solver:
  • 15 Answers
There may be 2 solutions for this problem:
The 1st solution:
The first thing you should do is locate the lock button on your ipod. Second make sure it's unlocked, lock it and wait for one second and then unlock it. Finally hold the inner Grey circle button in the center of the ipod until you see the apple logo appear on your screen.
The 2nd Solution:
Plug in your ipod and click on your ipod in your itunes library. By doing so you should be on your contents tab. Click on the settings tab and then click on restore. This should restore all your defaults on your ipod. Before you do all this; make sure you back upIpod 30GB - 1.gif your ipod library if you don't currently have them in your itunes library.
If this solution helps you out please give rate me and leave a comment. Thank you...
Posted on Mar 15, 2008
Ipod HD or logic board gone? SDRAM full test freezes!!!!
Getting the components wet is not a good start. There is most likely liquid damage on the parts even if you can't see them. And even over time corrosion to iPod can happen. Much like the Statue of Libery, it used to be copper, and now its green from long exposure to moisture.
Mar 09, 2017 | Apple iPod video 5th Generation
Stuck on sdram full test, how to reset?
visit the link below: It will guide you on how to reset your ipod.
Read and follow steps/instructions gradually on how to reset your ipod.
http://www.wikihow.com/Reset-an-iPod
Good luck.
Apr 22, 2010 | Apple iPod MA446LL/A MP3 Player
It says sdram full test reset to continue and is flashing
make sure your ipod is in the on position push the middle button & the menu button @ the same time for about 5-10 seconds you will see and apple appear just let it reset itself
Jan 08, 2010 | Apple iPod MA446LL/A MP3 Player
MY white apple Ipod 30Gb is stuck on SDRAM Full Test. It is flashing on and off. What do i do?
Try restoring it. go to your ipod summary, click restore, then sync back on all of your songs, videos, etc.
Jul 19, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb black
Hold down the middle and menu buttons at the same time for about 10 seconds. this will restart the ipod.
hope this helps and good lcuk!
Jaxon
Oct 03, 2008 | Apple iPod MA446LL/A MP3 Player
Unlock my ipod
I assume the unlocking your ipod is the combination that locks the screen and not the little white tab on the top of the iPod. By plugging the iPod into itunes it should unlock it. By restoring your iPod you erase the lock but also your music. If may stay unlocked when you remove it from the computer. Good luck.
Aug 26, 2008 | Apple iPod MA446LL/A MP3 Player
My IPOD frozen
Try pushing the centre button and the top of the click wheel for 10 seconds, which should reset the ipod.
see http://tinyurl.com/fnf6p
Jan 12, 2008 | Apple iPod MA446LL/A MP3 Player
I-Pod wheel broken?
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
HOW CAN I UNLOCK MY 30GB IPOD
plug in ur ipod to the computer then go to the start menu then go to control panel.then click on apperance, after that u should see alot of options but u need to click on the option that says folder options. then the window that pops up from that there will be tabs at the top u need to click on the one that says view. then go down to where it says hidden files and folders and click on the one that says that u want to show them. then click apply at the bottom corner. then go into my computer and click on the ipod icon then there shouuld be a folder that says locked folder click on it then in the next window just rename the files as _unlocked then u should be able to disconnect your ipod and be able to jam out.... it worked for my 120 gb ipod
Nov 27, 2007 | Apple iPod MP3 Player
466 people viewed this question
 Grubhead
Grubhead
