Question about Dishwashers
Dishes unclean, don't dry, smells
Does not always clean dishes well, smells. Researched test sequences, found for every model but this one!
  • 1 more comment
  • cmcq7 Mar 15, 2008
    Hey, thanks! It's a Bosch SHU 9900. The appliance repair company has been here 7 times. At first, the machine wasn't draining or filling. They fixed that, and I even sat there and watched the mechanisms working (pump, etc) during a full cycle with them. Before all this - everything came out like new - no matter how bad they went in. Now - it's a **** shoot. I've noticed two things - before, when I opened the door during a cycle, the spray arm used to "spit at me" and hit (the controls are inside so you can't stop the machine first). Now, it's a pretty weak attempt at a "spit". Then, I noticed that the water was luke warm during the pre-wash and that the dishes were not drying. I stopped using the pre-wash, turned my hot water heater to HIGH, run the tap first, and although the water in the bottom of the tub is hot, it's not scalding and the dishes still come "so so" and not as dry as they used to.
  • Jacques Aferiat Jan 01, 2009
    Plus my Bosch SHU 9900 does not drain.
  • Ian Greenland May 11, 2010
    make and model please
    Sergeant:
  • 351 Answers
It sounds like theres not enough water in the machine if you are on hot water connection and it to hot you can damge the valve,try starting the dishwasher then when it starts to wash open the door a put in a few extra liters of water in and see if it sounds like its washing stronger that wont fix the problem but it will let you know if its a water inlet fault.sometimes you have to connect a dishwasher to cold water and they all heat themselves.ive had one bosch that was playing up because of the water temp going in and the pressure.if theres not enough water in it you will get a poor wash and not wash the soap out of the dispenser.hope this helps.ian
Posted on Mar 19, 2008
Any ideas as to why dishes do not come clean?
Their cold be a couple of reasons. Are your dishes stacked too close together inhibiting the water from getting to the dishes? Are you putting in enough soap to get the job done? How dirty are the dishes and how long has the food dried on the dishes? when I have a lot of dishes I always put the dishwasher on high temp to make sure the dishes get clean!
Mar 07, 2015 | Dishwashers
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a residue on my dishes after washing.
It really helps to know the Make and Model of your dishwasher.
Recommend either Electrosol or Cascade powder. Do not use gel or tablets in any dishwasher.
If problems continue, have the heating element checked because that is another common reason for unclean dishes.
Mar 23, 2009 | Dishwashers
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Jun 05, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
333 people viewed this question
Top Dishwashers Experts
