Question about Dryers
Dryer making noise like pulley in going out
How do you look inside the dryer to ee what is wrong, like the pulley making noise
    Sergeant:
  • 351 Answers
Most dryers you can remove the back panel and run it.but some have the elements attached to them so it makes it hard to test,dont know what make and model you have.it could also be a motor bearing or drum bearing.hope this helps.
Posted on Mar 15, 2008
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
How do I replace the dryer belt on a maytag dryer model #pye2300ayw. How do you connect to the pulley and get the belt around the drum?
lift the hood by pushing in clip on either side. remove two screw at top inside to remove front. unplug first. thats as far as we go there. remove belt out of dryer. take new belt and put on drum groove side down, get it uniform around drum. putting belt on pulley might be easier to do from behind for you. two screws to remove small access panel.take belt under pulley and over and around motor pulley. turn drum slowiy to make sure belt is not twisted. this belt can only go on a couple ways and one is obviously wrong. good luck.
Jan 30, 2010 | Maytag Dryers
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
My dryer makes a scweeking noise as it spins
check the motor bearing maybe it needs some lubrication.
Aug 06, 2009 | Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
