Question about Sharp 25L-M100 25" TV
Need help programming channels
How do I program my TV to scan for channels?
  • Anonymous Mar 24, 2008
    My sharp tv model no is 29ASX8. My tv's menu is in chinese how do i change into english?
  • 129 Answers
Good day.
Go to menu and look for set up and choose auto scan.
chris
Posted on Mar 28, 2008
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Need to program cable remote (att) to tv ( SK-32H640G) do i need a code?
You can do it one of two ways, you can enter a code, (for a Westinghouse TV, normally use the Sony codes) or you can scan for channels. To scan you can normally enter a code sequence which will come in your booklet when you install ATT, you will need to enter the code sequence and scan using channel up until your TV turns off. One the TV is turned off, you will need to press the TV button on your remote and your TV is now programmed. For more information or if you need live help please send me an email to westytech@westinghousedigital.com
Oct 22, 2010 | Televison & Video
NEED CODES FOR RCA CONVERTER BOX TO PROGRAM TV TO REMOTE
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Jan 23, 2010 | Televison & Video
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Sharp 25L-M100 25" TV Logo
131 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
