Question about HP LaserJet 4100 Printer
HP 4100 Toner out
New hp 61X toner allso saying toner out. and that toner is working in another printer
    New Friend:
  • 159 Answers
Please tray to reset printer cold reset turn the printer off then press the go button then turn the printer on stay press go button when the message on control panel appear cold reset
Posted on Mar 19, 2008
SOURCE:
REPLACE toner cartridge
See the illustrated instructions beginning on page 88 of http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl10335/bpl10335.pdf for removing and reinstalling the toner cartridge.
Jul 29, 2013 | HP LaserJet 4100 Printer
Hp laserjet 4100 show message "Toner out". I can't print anything. Help me!!!
TONER OUT
The toner cartridge has run out of toner.
Depending on how the printer has been configured, it will either continue to print or stop.
Due to the resolution of the toner level sensor, it is possible that a small amount of toner (less than one percent) might still be present in the cartridge.
1. If the printer has stopped, you can resume printing by pressing GO for each job.
2. Replace the toner cartridge.
Jul 14, 2011 | HP LaserJet 4100 Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
Toner smears across envelopes when printed. I've cleaned the printer, cleaned the fuser many times (via 'create cleaning page' as suggested from HP) and still have the same issue. This used to not be a...
This might be a cartridge issue. You should also ensure that you have the media type set to envelope as this slows the pirnter down and provides best print quality. If the toner cartridge is not an OEM it might me the issue as well as toner quality on remans varies dramatically.
Mar 24, 2011 | HP LaserJet 4100 Printer
Printer will not read toner.
Did it ever work? If it was printing before, what happened right before the toner error appeared. Did you replace the toner(this is an HP toner cartridge, right?), did you have a paper jam....?
Sep 24, 2010 | HP LaserJet 4100 Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
Display says toner out even with new cart. Setting new cart message in resets menu to yes does not work, selection reverts back to no. Customer is using reman carts.
A number of companies use a fuse that blows when the cartridge is low. If the fuse is not replaced, it will still say "toner out". The reman should have replaced it.
Jul 27, 2009 | HP LaserJet 4100 Printer
HP 2550L says toner is low when it isn't
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP LaserJet 2550L Printer
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
Toner c8061x
If the line only prints with your new toner cartridge that means that the cartridge is defective. You can inspect the drum to see if there is something stuck in the center of it. If not, try to return it and get another one.
Aug 23, 2007 | HP LaserJet 4100dtn Printer
HP LaserJet 4100 Printer Logo
1,768 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
