Question about Acer Aspire L310 - Core 2 Duo E6300 1.86 GHz (S6479432) PC Desktop
No sound thru Altec Lansing speakers on computer
Not sure when, but lost sound on my computer. tried another pair of speakers and got sound, so i know it is the speakers. They are Altec Lansing, with a subwoof and two speakers. Connection goes from compuet to sub, and on to speakers. Both sub and speakers are getting power....Any thoughts ?? thanks.
  • Rapid Rabbit Mar 15, 2008
    "can you do a continuity check on the prime and ground of those ? " ....maybe, if i was sure what that was. i tried substituing another cable; didn't have an exact match but close, and that didn't make any diff. not sure about plugs going into the back of the computer though...any further explanation appreciated. thanks.
  • Anonymous Mar 30, 2014
    the speaker is old altec lansing acs45
    Genius:
  • 3,587 Answers
Maybe the plugs going into the back of computer are unhappy..can you do a continuity check on the prime and ground of those?
Posted on Mar 15, 2008
  • Patrick Michaels
    Patrick Michaels Mar 15, 2008
    continuity is done with an ohm meter..
SOURCE:
Problem Sound Driver Altec lansing ACS 295
Hi names Rui try downloading the sound driver here http://www.computerdriverfinder.com/altec-driver.php you will find all the latest sound drivers for altec lansing in this site if it still doesn't work try calling costomer service so they can provide you with better solutions..
try to dl a driver 1st if all else fail that your last option.....
Jul 17, 2011 | Altec Lansing ACS 295 Computer Speakers
Only one in the pair of altec lansing speakers is working.....the other one with volume control on it is'nt working ...what should i do ??
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 07, 2011 | Altec Lansing Multimedia Computer Speakers
Computer not seeing Altec Lansing BX1020 speakers
go to start>settings control panel> click on system then click on device manager. Make sure that everything is working properly then in control panel click sound. if that is all working. Make sure you have the speakers connected in the right spot. You may also want to try the speakers on another computer to isolate exactly what the problem is.
Thank you,
lee
Nov 10, 2009 | Altec Lansing BX1020 Computer Speakers
I lost the CD Drivers. can some one help me!! thx..
You can Google "Altec Lansing Drivers Download" and get a number of resources returned. May have to register to download them but...
May 02, 2009 | Altec Lansing Multimedia Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
Device Manual Altec Lansing 251 computer speakers
go to link below
www.eoneonline.co.nz/shop/CP/Speakers/Altec+Lansing/S2012.html
May 13, 2008 | Altec Lansing ACS 251 Computer Speakers
Driver/installer
No drivers are required for speakers.
It may be a problem with your sound card.
Mar 27, 2008 | Audio Players & Recorders
Acer Aspire L310 - Core 2 Duo E6300 1.86 GHz (S6479432) PC Desktop Logo
174 people viewed this question
Ekse
Alun Cox
