Question about Panasonic PT-52LCX65 44" HDTV
Panasonic PT-44LCX65 Projection TV
Error display in middle of screen says " Air filter cleaning recomended at this time". I have been all over this set and can't find an Air filter so I changed the bulb because there has been so much decussion on how bad they are, but that didn't fix the problem. Is there a way to reset this error code? What do you think is the problem?
  • NICOLE WY May 11, 2008
    I HAVE THE SAME PROBLEM HELP I HAVE BEEN ALL THROUGH THE TV AND I CANT FIND ANY TYPE OF AIR FILTER
  • mrganjj48 Oct 15, 2008
    my tv has that same error message on it.then it shuts of i cant fix it for nothing
    Sergeant:
  • 284 Answers
There is a filter in the front of the machine, right beside the lamp door theres another one. blow that out with can air will kill the error for a while then you might needs to get it serviced because one of the fans is caked with dirt and if you dont know electronics i would not try to take it apart to clean it.
Posted on Sep 10, 2008
SOURCE:
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic tv model pt-44lcx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
May 27, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
My panasonic pt-44lcx65
The fix for the air filter problem also you are probably getting the on screen message clogged filter also. It can be repaired by relacing the light engine (VERY EXPENSIVE) or remove the light engine and clean the filter much less cost infact none if you know how.
To clean the filter you must remove light engine and you will see at the top a black housing with two screws that must be removed to remove light engine.
A service maual on how to remove light engine is very helpful wich can be ordered on the internet. Any way you want to remove 4 screws from the housing you will then see the filter and 4 more screws to remove in all four corners, remove the screws and then pry the rectangular filter out of the assembly. This may take some effert so be careful. Look at filter through light it will probably be dirty wash with water and blow it out with comprssed air look at it through to insure it is clean then reinstall .Reassemble and you should be good to go.
Jan 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Were is the air filter?
The air filter is in front of the tv pop off the front and it is in a screwed panel you can take it off but i vac it out and air dust it out and it works great u need to not smoke around the tv or burn candles around it hope it helps
Jan 07, 2009 | Panasonic PT-44LCX65 Television
Panasonic
The air filter should be a user-accessible thing. Consult your owners manual for details. Can you find the manual?
Dec 30, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
1,146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
