Question about Cell Phones
Problem tryng to connect my phone to computer
I just bought a Motorola V9m I am having problems connecting to the program that came with it. ie to download music etc. I was connected and then the next time I try to connect it doesn't recognize my phone. Or it is trying to download a modem not my phone. Any ideas of why this would be happening
  • gwen_fst Mar 15, 2008
    I have done both of those things a number of times. Thanks anyway. Maybe someone else has a suggestion
Please remove your programe on computer and re installing it.
or
check USB cable is properly plugged or not
Posted on Mar 15, 2008
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Verizon V9M bluetooth cell phone does not fully work with car
I have the same problem and thus far my research shows that the V9M is NOT a supported phone on the 2010 E class. You can store manually numbers into the car's system.
Aug 23, 2009 | Cell Phones
How do I get music on my Motorola Razr2 v9m?
try unistalling the pc suit for your cell phone and re-installing it with your phone conected
Jun 15, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
I Cannot connect to Phone Tools via USB with Motorazr2 V9m?!?!?!?
I have the same problem as your's mine is also not listed on the List. What I did the first time I configured my MOTORAZR2 V9 is Open the main menu (I hope you do the same) >Select CONNECTION> CHOOSE between BLUETOOTH LINK or USB SETTINGS> In Bluetooth > Select SETUP>SELECT POWER ON. Now you have tour BLUETOOTH ON. USB SETTINGS is more easier all you need is USB TRANSFER DATA CABLE (as I understands it comes with your hand phone as in mine)
Feb 24, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Unlock code
It is usually the last 4 digits of your cell phone number.
Jan 18, 2009 | Verizon Communications Motorola MOTORAZR2...
Motorola MOTORAZR² V9m
Go to Menu/settings/initial setup/master reset enter 6 zero ok.
Similar Menu/setting/initial setup/master clear enter 6 zero ok.
Before to do that function,copy all phone book to simcard.
Dec 26, 2008 | Verizon Communications Motorola MOTORAZR2...
I need help uploading music on the razr2 V9m.
i want know that whether you mobile detected by computer or not if not please insert driver again
Dec 23, 2008 | Motorola Mobility RAZR V3
Mp3 driver motorola sliver L7c vista pro
I found these drivers for XP here: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_32.zip
And for Vista drivers, use this address: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_64.zip
Alternatively, you can download and install the USB Drivers from http://developer.motorola.com. These drivers are often newer than the ones above, but you will need to create a user-id first. After logging in with the new user-id, search for "usb driver", or navigate directly to http://developer.motorola.com/docstools/USB_Drivers/Handset_USB_Driver
After downloading and installing the Motorola Driver, you will need to run the Motorola Driver Installer program by going to "Windows->Start->Programs->Motorola Driver Installer->Motorola Driver Installer.exe".
This alternate Motorola USB Driver is required for most phone models from Verizon, Alltel, and US Cellular. Some of these models include:
Alltel V3a, Verizon K1m, Verizon Maxx Ve, Verizon L7c, Verizon W385, Verizon W755, Verizon Razr2 V9m, Verizon V750, Alltel Razr2 V9m, US Cellular Razr2 V9m, Sprint V3m, Sprint K1m. I hope this helps someone. :o)
Jul 03, 2008 | Motorola Cell Phones
Locked razr 2 v9m
the default code is 000000 - security and the unlock default is 1234....you do not need to reflash the phone take the phone to a mobile service center and have them reset it for you.
Feb 23, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
