Pevey combo 115 how do i EQ it - Audio Players & Recorders
  • rafaeljjl Dec 12, 2008
    l need to get the schematic of the peavy combo 115.l have to repair my one.please help me.
    Problem Solver:
  • 10 Answers
Assuming you're referring to the Peavey Combo 115 amp, you enable the equalization feature by pressing the button Identified as "EQ In, EQ Out". With the button pressed (In), you can modify the tone characteristics of your instrument using the 7 different frequency range adjusters. Leaving all at zero does not change your signal at all. You may want to check Wikipedia for a definition of decibel changes to get a good feel for how the equalizer works.
Posted on Mar 15, 2008
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Peavey tnt 115 schematics
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Feb 26, 2012 | Peavey Electronics Peavey Tour Tnt 115...
Ampeg BA600 115 combo power cuts in and out!
Broken cable jacks are most common problem. Cracked circuit boards and bad soldering is second on the list.
Jul 14, 2011 | Ampeg BA600 115 1 x 15 Bass Combo
My kids broke my gain pod and my eq on my peavy tko 115 where can i get the replacement parts from and what is the discription numbers.
Best to get these from Peavey.
Contact the parts dept by email at:
parts@peavey.com
Be sure to give your model and serial number and the exact name of the front panel controls that are damaged.
Nov 12, 2009 | Peavey Music
Pevey CS-800 old fuse not present. What is the correct fuse type for replacement. The fuse holder is on the back of Amp. Thanks.
One of the latest versions has a 15Amp fuse at 115V.
If your CS-800 is connected to 220V, you have to use 7,5Amp (8Amp is OK).
regards,
Gerard
Sep 26, 2009 | Sony STR-DE595 5-Channel Amplifier
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
I have a numark cd1 combo and i need to connect it my preamp and
1-RCA outs on the cd1, right? Route to ins on the preamp (use adapters if necessary, you don't say what pre and eq you have)
2- if the pre has an effect loop/aux bus or whatever, install the eq in the loop, and output the pre to the ins on the power amp; otherwise route the outs from the pre through the ins on eq then to power amp ins.
Jul 01, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
 Grubhead
Grubhead
