Question about Toshiba 50HX81 50" Rear Projection Television
Toshiba 50hx81 power light just blinks
You mentioned you have a solution to the blinking power light on the toshiba 50hx81.
Thanks
Doug
dougstrash3atcomcastdotnet
    Genius:
  • 1,694 Answers
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Posted on Mar 15, 2008
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Tv will not turn on blinking als red light
the answer for this problem happens to be a blown projector or broken projector bulb it needs to be taken to a shop and be replaced
Dec 12, 2009 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 27, 2009 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
No picture
I had the same issue, the blinking power light is a indicator...It cost me 400 bucks to have repair man fix.
Nov 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50
1) Blown fuse ( soldered in) = caused by bad solder connects.
2) For repair = pull chassis, solder connects,replace fuse
3) Replace convergence IC's ( possibly damaged)
4) Re-assemble,test
Oct 22, 2007 | Toshiba 50HX81 50" Rear Projection...
Red power light keeps blinking and wont come on
The first thing to try is to unplug the unit from the wall for about 15 minutes,if this does not work you will need the assistance of a servicer to diagnose the problem,if you are familiar with tv service you can check the horizontal output transistor for a short,sometimes it fails for no reason and other times it goes bad along with the horizontal output transformer also know as flyback.Be careful if you decide to check this yourself.
Oct 02, 2006 | Toshiba 50HX81 50" Rear Projection...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
190 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
