Help! i have a seagate 750gb freeagent pro and won't show up on my computer anymore. in fact everytime i turn it on it gives me a beeping sound every few seconds and stops after about 15 or so beeps. how can i fix it?
    Genius:
  • 1,027 Answers
Download seagate tools and run the diagnostic utility...this will tell you what's wrong. you can download powermax from same page and this utility can recertify small errors on the hard drive without erasing data.
Posted on Mar 15, 2008
My Seagate FreeAgent Pro HD won't turn on anymore. Any suggestions?
If it's not turning on at all anymore and it's plugged in properly, there isn't much you can do. Everything I've purchased from SeaGate wasn't meant to last. In other words, after a year or so, they quit working. It's probably some kind of marketing scheme to get you to spend more money. Open up the case, take out the drive and stick it in your computer. That way you can still salvage what's left on it.
Dec 26, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer cannot find external drive
This sounds like it might of formatted the hard drive aswel and now needs partitioning.
Go to control panel then system tools then computer management.
on the left click disc management and see if it shows in this.
if it dont then you need to take the hard drive out of the case, and plug it into the computer inside via the sata cable and partion it in the boot options.
hope this helps
please rate
Feb 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 750GB
try checking ur USB ports.May be the drive is not supported by ur usb .Try connectin to another system with same OS
Aug 28, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
