Question about RCA HD52W59 HDTV Projection Television
Bad power source
Is that some sort of panel inside nick?
  • 73 Answers
Look for screw driver type what u would use to adjust focas things ics look in back take panel off look for adjustments on main bord ok that u ould do
Posted on Mar 15, 2008
  • Anonymous Mar 15, 2008
    opps wrong msg panel inside back panel then big squre power unit u would need to re do get ne wone becarefull if u never done this dont kill yourself by shocking yourself even unpluged u will get nailed ok best u bring tech in to change out power
SOURCE:
No power on LG TV
Could be power supply failure
Oct 16, 2016 | LG Televison & Video
Smelling carbon monoxide emissions
Please shut down the furnace and find an alternate source of heat immediately!!! In older furnaces the heat exchanger goes bad it will crack or burn holes in it. You need to replace the exchanger and or furnace, there are no ands, ifs, or buts about it. This is nick named the silent killer for a reason people carbon monoxide poisoning is no joking matter. You need to ventilate the house well and get out in to fresh air, signs of carbon monoxide poisoning are light headed, feeling tired and some get sort of sick to your stomach. Look there is no price that can be put on a human life, and I do understand that this is bad timing with the holidays and all, but this problem requires immediate attention PLEASE!!
Dec 28, 2010 | Goodman GMS90703BXA Heater
NO POWER TO TV POWERSPEC TV MODEL V30DMBT TESTED POWER SOURCE AND TURNED POWER BUTTON OFF AND ON
The power supply circuit inside the tv may be bad. Normally a bad capacitor is the culprit. You may visually inspect the circuit (the first circuit connected to the power chord inside) for leaks or swollen capacitor. The entire power supply circuit may have gone bad. Test if there is power coming out of the circuit to verify.
Jun 08, 2010 | Televison & Video
Monitor won't stay on more then a second or two
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 31, 2010 | Dell E193FPC 19" TFT LCD Flat Panel...
Laptop will not turn on
Consider taking it for repair. The most common cause of this sort of problem can be: Bad capacitors (Bulging top/leaking) Blown resistors, diodes, transistors (They normally leave a black mark) or a fuse inside.
Apr 11, 2010 | HP Pavilion dv6000z Notebook
Cant tune tv in to use xbox 360
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
Mar 23, 2010 | Televison & Video
We found water on the kitchen floor by and under the dishwasher
Check along the bottom inside of the door if the edge is cut up or has nicks in it from silverware being pulled across it than that is the source of the leak try putting a couple of strips of tape along that edge and run another cycle if it stops leaking or leaks less you have to replace the inside door panel and it will work fine again cost between 20 and 40 dollars depending on where you order it from
Jan 30, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Linksys WRTU54G-TM router does not power on
1) Try plugging into a different outlet
2) While plugged in, try resetting with the little button on the back.
If neither of those work (and I don't really expect they will), this means you have a bad transformer, or a bad power supply inside the router. Either one will require you to send it back to Linksys for repair. Sorry I don't have better news for you.
Nick
Nov 27, 2008 | Linksys (WRT54GC) Router
Power source
well on older unit like u got i would say aroun 200 to 300 instaled
Mar 15, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
