Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Dispenser in door inop
The dispenser panel in door inop, no water, no ice, no light.
The ice maker works fine.
    President:
  • KitchenAid Master
  • 2,651 Answers
I would look to the wire harness under hinge(its hidden in a plastic webbing), 7 or 8 wires running through hinge creating a pinch point and shearing wire(s), only solution offered by kit aid is door replacement (harness not available, molded into door) but at close to $700 for a new door, some well placed solder mends to the connections will work quite well( wire nuts to big)
Posted on Mar 15, 2008
SOURCE:
Ice maker reset
Either valve solenoid supplying water to ice maker is bad, or supply tube to ice maker is frozen(which is typically caused by leaky water valve), or ice maker is bad.
Sep 19, 2018 | Refrigerators
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Water at door stopped working. water still comes to ice maker. no damage to electronics panel. Ice dispenser, whole and crushed works fine. is there a relay in the water circuit that fails? Or, is a...
I have the exact same problem. Ice maker works but nothing at the water dispenser. The light come on when I press the lever and I hear a click. But nothing like water "trying" to be pumped. I am nervous it is more than just a frozen water line. Anyone else have this problem or a solution?
Dec 09, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Feb 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Jan 06, 2008 | Refrigerators
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
89 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
