That information is in the user manual which can b down loaded from the hp site.. or simply go into the menu on the display and into setup you should find it
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers. Please note: If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Set the fax machine to Manual Receive. Set your answering machine to 4 or 5 rings. When the phone rings, pick it up, if you hear the chirping of a sending fax machine, press the Start Key on the fax and then hang up. The two faxes will communicate and you will receive your fax.
Set rings to answer You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer. TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2. 1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter. Rings to Answer will display. 2. Press Start/Enter. 3. Enter the number of rings you want (2-7) and press Start/Enter. The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming. • The additional ring may occur once for a fax call • The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time. I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.
It worked for me. Hope this works for you too.
Setting Ring Delay: The Ring Delay setting determines the number of
times the fax machine rings before it answers. If you have extension
phones on the same line as the fax machine, keep the Ring Delay at a
default setting of 4: 1 Press Function/Set, 2, 1. 2 Press < or
> to select how many times the line rings before the fax machine
answers (00 – 04) and press Function/Set. If you select 00, the line
doesn’t ring at all. 3 Press Stop to exit.
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
