Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker not working
Kenmore elite 106.56716500 refrigerator- tried a new water filter even though the sears mgr. said the water filter doesn't have anything to do with the ice maker. Tried turning it on and off( the first time the ice maker quit, this worked but not this time) what does the infrared light supposed to do? I'm buying my ice from grocery and putting it in the icebin in the meantime? is that harmful? help, tx
  • jakenney Jan 27, 2009
    Same problem...106.56716500 in the tray but its not harvesting it...infrared light blinks sometimes and sometimes it doesn't....tried turning the whole unit off for 30 seconds and resetting it..didn't do anything.
    Just called Sears to send out a service tech.
    Problem Solver:
  • 10 Answers
In my freezer, there's an infrared beam positioned over the top of the ice bin. If the bin is full of ice, it blocks the beam and no ice can be made. In addition, when you open the freezer door, a small (2x3") door opens in the freezer to block the beam, again to prevent ice from being made while the door is open. Is anything blocking the path of this beam from one side of the freezer to the other?
Posted on Mar 15, 2008
My Kenmore Elite 3 cycle under counter ice maker has stopped making ice
check the filter when was it changed? is the water turned off call sears for help
May 02, 2016 | Kenmore Refrigerators
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working but water is new filter elite 75542 40re1451
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Jun 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
374 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
