Dual channel problem
Hi! i am having a hard time how to run my system in dual channel memory.i am running vista ultimate 32 bit with 2GB of DDR2 533 of RAM,CPU Intel pentium D 2.66 ghz and using Nvidia 8500 GT 512 MB.i ran cpuid and it reported that im running in single channel no doubt why my windows experience index base score is only 2.5.can anybody help me resolve this?
  • Anonymous Jan 25, 2009
    my motherboard is asus p5s-mx se running vista with x2 1gb of ram which are the same but will only show up in single channel,dual core/core2 dou,any one help to run this in dual core.
  • 148 Answers
Is the 2 GB of memory in two identical 1GB sticks? what slots are they installed in? Check to make sure they are installed in slots 1 and 3 (usually - I dont know what motherboard you are using.), and the motherboard is enabled to dual channel mode .
Posted on Mar 15, 2008
Hi!... I am using window 7 ultimate 64 bit. I am facing the problem of full HD. earlier when me using window Vista that has been ok. If there is any solution plz let me know!.. thanks Moiz Raja
windows 7 os requires atleast 16GB avilable space while windows vista requires atleast 15gb. It could be true that your system requirements are not sufficient for the new os you want to install
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • DVD-ROM drive
If you want to run Windows Vista on your PC, here's what it takes:
  • 1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
  • 40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
  • Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
  • DVD-ROM drive
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | HP w1907 LCD Monitor
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
I have an older Acer Aspire 3000... it recently became to cluttered and when I tried to reformat loading windows 7 ultimate, it stopped saying it couldn't find everything it needed. I'm fairly certain its...
Not all systems are supported by Windows 7. Infact many items that were supported by vista are not supported in windows 7.
looking at your system specs you woudl originally have AMD Mobile Sempron 3000+ / 1.8 GHz , 256mb ram and windows xp home as your original.
this system does not meet the minimum requirements to run Windows 7 Ultimate or Windows 7 at all.
minimum specs for windows 7 are
  • i do not recommend a 1ghz system. i would recommend a 2ghz or better with 2GB of memory for a basic version
    Feb 11, 2010 | Acer Aspire 6930-6771 Laptop
    If I unstall DDR400 memory as as follows: DDR1 & DDR3 : 512MB each DDR2 & DDR4 : 256MB each making 1.5 GB in total, will dual channel technology be activated?
    Definitely not. Dual channel technology requires that the 2 RAM modules installed in each bank be of the same capacity, data rate, & even better be from the same manufacturer.
    Oct 30, 2009 | Gigabyte GA-8I915G Pro Motherboard
    System requirements of vista
    For Vista Home Basic >>>
    • 1 GHz 32-bit (x86) or 64-bit (x64) processor
    • 512 MB of system memory
    • 20 GB hard drive with at least 15 GB of available space
    • Support for DirectX 9 graphics and 32 MB of graphics memory
    • DVD-ROM drive
    • Audio Output
    • Internet access (fees may apply)
    Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
    While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
    For Vista Home Premium, Business and Ultimate >>>>>>
    • 1 GB of system memory
    • Support for DirectX 9 graphics with:
      • WDDM Driver
      • 128 MB of graphics memory (minimum)
      • Pixel Shader 2.0 in hardware
      • 32 bits per pixel
    • DVD-ROM drive
    • Audio Output
    Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
    Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
    UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
    Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
    • 800 MHz processor and 512 MB of system memory
    • Support for Super VGA graphics
    • CD-ROM drive
    Regards.
    Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
    Vista RAM usage ?
    The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
    Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
    Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
    Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
    Apr 26, 2009 | Dell Dimension 3100 PC Desktop
    32 bit program to 64 bit opperating system
    From the Autocad webiste:
    System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
    • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
    • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
    Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
    Here's how you should be able to run it in compatibility mode:
    1. Right click on the Autocad Icon in your start menu
    2. click on Properties
    3. click on the Compatibility tab at the top
    4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
    I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
    Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
    Memory confusion different readings
    It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
    Jan 17, 2009 | Mach Speed (S755) Motherboard
    4 GiG memory
    Your motherboard doesnot offer dual channel memory architechture and 2x2GB memory is taken in sigle channel mode. Apart from that 32bit Operating Systems don't recognise memory over 3 Gb. So you have the following options...
    1. Attach only one 2GB
    2. Attach 2GB + 1GB
    3. Move up to a 64bit OS with your current 2x2GB memory modules.
    Please collect memory module of the same frequency if you consider option 2.
    Sep 08, 2008 | Computers & Internet
    Problem with DG31PR while loading windows 2003 server with 4gb ram
    You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
    Jul 29, 2008 | Intel DG31PR Motherboard
    Computers & Internet Logo
    908 people viewed this question
    Alun Cox
    David Payne
    David Payne
