Question about ASUS A7V8X Motherboard
Installation help with Asus kt400 motherboard
Everything is installed and works, system boots fine. after 10 seconds a red light appears near Fan 3.
    Problem Solver:
  • 13 Answers
Did u reassemble the CPU fan, it you did so, u have u do it again and add some heat zinc compound over ur processor ...andthen place ur fan, it may be due to that...
Posted on Mar 15, 2008
2 Suggested Answers
SOURCE: Installation help with Asus kt400 motherboard
how syour ram power grounded well
Dram Led on my motherboard blinks red twice
Don't panic. take a good light above your computer and start checking if every card and every connector is still correct inserted. Feel if nothing is lose. Even cards you did fasten with a screw, remove the screw and look and feel if the card was inserted correct. Everything you inserted in the motherboard should be checked. It could be a card you did not put in correct at the first time, but still made contact and only got lose because of some tension to shock.
Jul 03, 2014 | ASUS - MOTHERBOARDS Asus M5a97 R2.0...
I need installation manual for asus via kt400 motherboard
You can download the User Guide (Installation Guide) of the ASUS A7V8X Motherboard by clicking here.
If you don’t have Acrobat Reader to open the downloaded pdf manual you can download the Acrobat Reader by clicking here.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
VIA KT400 Chipset Driver update fried my ATI Radeon 9550 AGP Card
AGP is a bit old for win7, i'd drop it. that said, if the ati card is an addin perhaps your onboard (via) chip is causing the problem. turn it off in your bios so that the install never even detects it and use drivers from ati.
Jun 09, 2009 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
I have a asus 256mb en7200gs graphic card it worked fine for a month but now it does not work when i install it with it's drivers it installs and after restarting my pc it just restarts just after coming...
remove the card, get the old drivers for the motherboard and reinstall them, then see if you can get the system running, if the problem continues to reboot every time you are going to have to reset the motherboard this means shorting out the bios and setting everything back to manufacture orignal setting, before doing this go in to bois and write down everything on the type of drive and all the information on that line
cyclinders
heads
precomp
sectors
lba
so one
how the systems boots firsat hd, dvd, cd, floppy
on the motherboard is a sitch 1-3, most of the time it is on 1-2, you need to move the switch 2-3 for a few seconds and move back to 1-2, reboot
go into cmos
set up everything the way it was before you reset the system everything should work fine
reinstall the video card and drivers
disabling old drivers
Feb 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Cannot boot up
maybe you must reset the bios in the motherboard. try to open your system then look for a 3 pin in the motherboard near in the CMOS battery.. it has a number 1,2 and 3 it is called jumper settings.... try to put the pin in number 2 and 3 then w8 after 10 seconds then gput it back to 1 and 2 in try to boot up.. ^^ i wish this could be help.. ^^
Feb 06, 2009 | Albatron Nforce2 (KX18D PRO II)...
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Fan will not work
the fan should be plugged into the 3 pin socket between the CPU and the RAM.
if the fan already in the right place, please let me know which shorting cap got moved.
Dec 01, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
ASUS A7V8X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
