Question about Lexmark X5250 All-In-One InkJet Printer
Printer does not print like the original
My Lexmark X5250 has started printing blue lines through any document which has color of any kind in the original-
I have uninstalled the printer and reinstalled with the supplied disk-
It prints properly in black when the options are set to print all colors in black and white-
This also happens in the scan and print mode-
What do you suggest??
Mortimer Jefferson Thurman Sr.
169 Tessie Drive
Jacksons Gap,Al. 36861-2522
Ph 256-825-4807
e-addys: [email protected]
    Genius:
  • 3,587 Answers
Posted on Mar 15, 2008
SOURCE:
Copies have blue background
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5200 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark X5250 All-In-One InkJet Printer
Lexmark z23
Be sure you have set your default printer when you were printing documents from internet.
Anyway are you saying that you print the whole page on the internet, and it's does not print anything?
Do you got error message?
Thanks,
Feb 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark X75 won't print in colour anymore
When you print a color document do you get any color output ?. You may want to try to print a test color document, consisting of say Red, Green and Blue color blocks. If any of the blocks is missing you may want to replace your color cartridge.
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5250 Printer
chech to see if the cartridge slot locks down the tab that locks the cartridge have been known to break. or run a maintenance check and clean the printer heads.
Sep 27, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250
ok..that's from a really bad printer power supply..can you check the output voltage on that power pack?
Mar 16, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250
wow..that is truly odd..no drivers? did you check this link out(under lexmark icon)..
Lexmark X5250 PAPER WONT AUTO-FEED
Very pesty!!! Ok, it may be a paper feeder issue. It could be a partially jammed roller or carriage, open up unit as if you were to change cartridge, use a torch to check for the tiniest paper block or foreign material. You would be surprised what can fall or accidenatlly get in them...funny that, i just cleared a tiny piece of toddler debris from my lexmark, and i missed it the first time. Also, paper sensors can start to go and die, hope it is not this!!! as it will need replacing if it is. If it is printing, it may also be too much info from pc to printer. Does it only do this at certain times or all the time? Try clearing the print jobs memory by printing a small document but click on print icon and choose cancel all print jobs. Wait until it does. Try printing again. Also open notepad as if you were to print it, right click on file and print, and check if printer says ready...indicating it is functioning status. this can help diagnose problems sometimes it will give you an error code or message you need.
Aug 11, 2007 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
