Question about Abit AMD K7 MB;VIA KT400;SATA,DDR400 (AT7MAXII) Motherboard
Installation help with Asus kt400 motherboard
Everything is installed and boots up fine, detecting all the hardware but there is a red light near the Fan 3 slot which turns the system off after about 10 seconds.
  • 73 Answers
How syour ram power grounded well
Posted on Mar 15, 2008
  • Anonymous Mar 15, 2008
    mobo screwed in nice tight cpu locked in soket
    cheak these
SOURCE:
I need installation manual for asus via kt400 motherboard
You can download the User Guide (Installation Guide) of the ASUS A7V8X Motherboard by clicking here.
If you don’t have Acrobat Reader to open the downloaded pdf manual you can download the Acrobat Reader by clicking here.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
A7V8X-X MOTHER BOARD MANUAL
You can download the required manual by clicking this link:
http://dlsvr04.asus.com/pub/ASUS/mb/socka/kt400/a7v8x-x/e1198_a7v8x-x.pdf
Alternate link: http://dlcdnas.asus.com/pub/ASUS/mb/socka/kt400/a7v8x-x/e1198_a7v8x-x.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 13, 2010 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
VIA KT400 Chipset Driver update fried my ATI Radeon 9550 AGP Card
AGP is a bit old for win7, i'd drop it. that said, if the ati card is an addin perhaps your onboard (via) chip is causing the problem. turn it off in your bios so that the install never even detects it and use drivers from ati.
Jun 09, 2009 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Jun 03, 2009 | ASUS K8V-MX Motherboard
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
May 13, 2009 | ASUS P4PE-X Motherboard
Installation of nvidia ge force 6800 gt series 512mb ddr2memory
this nothing new this asus motherborads try and reset your cmos some times this works and you need to make sure your board can take your gf card has some of them can only take 128bit or 256 or 512 or 1gb
Mar 10, 2009 | ASUS P5GZ-MX Motherboard
Not installing windows xp with asus k8v-mx motherboard
Sounds stupid but I have seen it happen. Make sure the cd in the first in the boot sequence in the set up. If that dont work make your c drive first. Give it a shot, may work..I love asus
Sep 23, 2008 | ASUS K8V-MX Motherboard
Did u reassemble the CPU fan, it you did so, u have u do it again and add some heat zinc compound over ur processor ...andthen place ur fan, it may be due to that...
Mar 15, 2008 | ASUS A7V8X Motherboard
Open Questions:
LeXmark Wireless Printer CUSTOMER service pHoNe:~{-1^85526O0O64-}nUmBeR USA Vuiary LeXmark Wireless Printer CUSTOMER service Number +1{85526O0O64}VuLogin Repair service center to resolve all LeXmark Wireless Printer tEcH SupPoRt pHoNe nUmBeR products. LeXmark Wireless Printer ROUTER is an American multinational company which was founded by Michael LeXmark Wireless Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, LeXmark Wireless Printer ROUTER support number, and selling of computer-related services and products. LeXmark Wireless Printer ROUTER Tech Support Phone Number Recently, LeXmark Wireless Printer ROUTER has been named the number LeXmark Wireless Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, LeXmark Wireless Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a LeXmark Wireless Printer ROUTER Service Tag or a LeXmark Wireless Printer ROUTER Get LeXmark Wireless Printer ROUTER Technical Support Phone Number and Customer Services. LeXmark Wireless Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 18, 2019 | Lexmark Computers & Internet
LeXmark Wireless Printer tEcH SupPoRt pHoNe nUmBeR:~{-1{85526O0O64^-} Vusary LeXmark Wireless Printer tech Support Number +1{{85526O0O64}VuLogin Repair service center to resolve all LeXmark Wireless Printer customer service phone Number products. LeXmark Wireless Printer ROUTER is an American multinational company which was founded by Michael LeXmark Wireless Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, LeXmark Wireless Printer ROUTER support number, and selling of computer-related services and products. LeXmark Wireless Printer ROUTER Tech Support Phone Number Recently, LeXmark Wireless Printer ROUTER has been named the number LeXmark Wireless Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, LeXmark Wireless Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a LeXmark Wireless Printer ROUTER Service Tag or a LeXmark Wireless Printer ROUTER Get LeXmark Wireless Printer ROUTER Technical Support Phone Number and Customer Services. LeXmark Wireless Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
See all Abit AMD K7 MB;VIA KT400;SATA,DDR400 (AT7MAXII) Questions
Abit AMD K7 MB;VIA KT400;SATA,DDR400 (AT7MAXII) Motherboard Logo
63 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
