Question about Canon PowerShot A400 Digital Camera
I dropped my camera and it is giving me an E18 error. It doesnt want to turn on. Help please. Should I take it apart? Canon Powershot A400. Thanks
  • ZaknLexismom Mar 15, 2008
    Thank you. It still doesnt work. It is making a god awful noise too. I think its toast!
I Dont Have a repair problem i was trying to get info on a warranty on my new phone .
Posted on Mar 15, 2008
  • 30 Answers
It may or may not working after water damage, i suggest and at this point you have nothing to lose,if u want u can try to take it apart but i will warn you, camera have lots of small parts and you might not remeber what goes where, i suggest save for another, when device are drop in water only about 5% turn out to be ok. good luck
  • 73 Answers
Try taking out sd card once maby u shocked the card
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
E18
Lens Drum gear broken so that it flash E:18,it need to replace
Mar 18, 2010 | Canon PowerShot A400 Digital Camera
I am facing e18 problem.Need to open a400 camera.Tell me the steps.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try. And for the A400, have actually had a lot of success with these, especially Fix #7.
Jan 31, 2010 | Canon PowerShot A400 Digital Camera
Turns off when trying to take photos and E18 comes
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon PowerShot A400 Digital Camera
E18 Error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
Feb 11, 2009 | Canon PowerShot A400 Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
Lens won't retract
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed two A400 cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 05, 2007 | Canon PowerShot A400 Digital Camera
Canon PowerShot A400 Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
