Question about Proview PA-32JK1A 32 in. LCD Television
Buzzing sound coming from speakers
There is a buzzing sound coming from the internal speakers, Its not a constant buzz, sometimes its loud the will go away for a few seconds then builds back to a loud buzz.
  • Zackoria Jun 23, 2008
    I have the same issue. It is worse if I am watching an HD channel.
    This is very strange, because I do not even have an audio signal going to the TV set. All audio goes to my home theatre system.
    This is driving me crazy.
    Only thing I can think to do is open up the TV and cut the actual wires going to the speakers.
    Anyone who has a fix for this please post.
    Thanks in advance
  • Anonymous Aug 02, 2008
    Proview 42-in LCD TV buzzing sound. I had the same problem. Took it in to a shop and they cleaned the internal contacts. No buzzing sound until just now, about 6 weeks later. Apparently the internal connection oxidize easily. Check with your local shop to see what they charge to clean them.
    New Friend:
32 inch flat screen works great when cold 5minutes screen goes all wavey and sound just screams very loud
Posted on Apr 17, 2011
  • 51 Answers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Posted on Sep 09, 2008
SOURCE:
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
When thermostat calls for heat, loud buzzing
That sound generally comes from a magnetic coil that is being energized. It could be from a compressor control or a furnace gas valve. In either case there is no danger involved it may buzz for years and unless you have money put aside for a heating mans adventure id just let it buzz until it gets so loud it just has to go. Sometimes the buzz just goes away. I know it sounds crazy and I understand one persons buzz is another persons nightmare. Its yer call. Hope this helped and good luck.
Oct 08, 2014 | Heating & Cooling
Buzzing sound car stereo
A lound buzzing sound is an indication that the Driver (transistor) for the amplifier final is bad. This is not so much a buzzing and it is extreme in loundness.
May 05, 2013 | Chrysler concorde amplifier. radio. ....
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Constant buzzing sound in all speakers
Sounds like either a transformer or amplifier problem. You haven't reversed polarity on the speaker connections? or changed the speaker sizes, Ohms, ect? Probably a resistor, diode, or condenser in the amplifier causing feedback through the speaker system. It's doubtful both speaker coils went out at the same time. Possible, but doubtful.And you mention that the volume "SPIKES" from time to time. Could be as simple as corrosion on the volume "pot". Basically a Rheostat that allows more signal the farther you turn the knob. If so, you can clean that yourself with a spray product available at any Radio Shack. It is for cleaning electonic components and leaves no residue. You could have this checked at any competant electronics shop, but BEWARE, the "Bench Fee" to test may be more than the value of the system. I would ask what the "bench fee" was to determine a problem, and then what the labor costs would be to repair either a transformer or amplifier with resistors, diodes, capacitors, ect. Electronic equipment tends to "break down" over time and use, and sometimes you can replace a component cheaper than repair. If part of a rack system, then you may want to retain this sub-part and repair may be your choice. I would ask about the fees to test, and the costs of labor to repair, before turning it over. How old is the system?
Sep 26, 2009 | Kenwood VR-7070 Receiver
PC Speakers Buzz at Random Times
bad connection broken fratured wire just touching dirty or oxidized plug connection
Aug 01, 2009 | Philips MMS 321 Computer Speakers
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Proview PA-32JK1A 32 in. LCD Television Logo
1,220 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Paul
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
