MPC 500 PROBLEM!!
HI I HAVE A PROBLEM WITH MY MPC 500. BASICALLY IF I TRY TO LOOP DRUMS OVER A 10 SECOND SAMPLE I'VE LOADED THE SAMPLE STOPS PLAYING PREMATURELY WHEN I HIT 2 OR 3 DRUMS IN A ROW REAL QUICK. HELP!!!
email: huddy_mj23@hotmail.com
You need to set your Parameters Params and make sure the you set enough bars for the sample.. if it cuts out you could try hitting the track button and putting the drums on track 2
Posted on Mar 26, 2008
WMA stream on a constant loop for my favourite radio station
Since other stations worked perfectly, perhaps the other station was streaming a loop.
Otherwise try this: Support Cobra Electronics Corporation
Mar 21, 2017 | Cobra Radio Communications
I play drums, and when playing with my QC15's on certain loud sounds seem to make the noise cancellation clip and cut out audio for a second. why is it doing this?
Does this problem only happen on when playing drums? For me, when my battery is running low, if I move my head back and forth quickly or lightly tap the right headphone, they will clip in and out briefly, but replacing the battery always fixes this. My guess is that you are playing drums a lot, your battery is running low, and you might be throwing your head around violently, causing a similar problem.
Feb 15, 2011 | Bose QC15 Headphones
Hi, I have an mpc 4000 and somehow I can't get it to play my samples in the main sequence mode. I recorded some drumsamples and I can hear them in the program. I can record a beat but it will only sound...
Hi - I thought this solution I read earlier may help you out - it was originally posted for another problem:
http://www.fixya.com/support/t519740-akai_mpc_4000_plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
Sep 24, 2010 | Akai MPC-4000 Plus Production Center (w/80...
I sample on mpc and a crazy computer noise repeatly comes out.. i cn still do a function but the noise still dnt stop
This usually means your digital buffer overloads. When you have added several layers on to a sound it can be to much. Try to sample the sound again. If it comes back try to take the sample in a lower bitrate. Maybe your maybe can not keep up with the bitrate.
Feb 23, 2010 | Akai Mpc1000 Music Production Center
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
How can the MPC 500 play the Samples on the Pads in real time?
You have to go to the sample edit page and move the start point to the beginning of the wave sample. Right now your start point is before the sample actually starts.
Oct 07, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Mpc 500
First ensure that you are saving into the right folder, on MPC HD and not into a subfolder, and that files are in correct midi format. Also ensure that connections to MPC are OK.
If connections and saved files are ok, then probably you need to reinstall Mpc 500software onto your computer, using disk provided with your Mpc 500.
Oct 19, 2008 | Akai Mpd16 Midi/USB Mpc-Style Drum Pad...
Akai MPC 4000 Plus
Apr 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Help
When youre in LOAD or DISK mode, does the mpc allow you to scroll through the cd? In what format are the samples. If the sample doesnt load, it wont play, but when selected, it should allow you to preview the sound. The 4000 allows users to import/load SND and WAV files.
The MPC4K should allow you to sample right out the box, but make sure you have the latest OS.
http://www.akaipro.com/support.php
try the 4k FAQ..
http://www.akaipro.com/supportfaqsMPC4000.php
It's also covered in the manual with you can download for free @
http://www.akaipro.com/supportdocuments.php#Z248
I know, who wants to hit a manual when you want to bang out....I'm a classic 2K owner, trust me I know, but sometimes the 5 minutes in checking the methods, saves you downtime, and gets you into funk mode quicker..
The 4k is also the first Mpc to come with onboard sounds, so check a preset, then check your cd, and if youre getting audio from the preset, then you know it's not the sound generator / synthesis chip. If you have a computer, try itunes or sound converter to switch the sound format, or look for a really nice low end application called CDXtract.
If youre banging out on halloween, youre my kinda MPC user.
Keep me posted.
Oct 31, 2007 | Akai MPC-4000 Plus Production Center (w/80...
157 people viewed this question
 Grubhead
Grubhead
